just got this problem solved but now i have or had a new one.
for the wiper problem i took it the place where they did my safety
the mech did watever it took for him to get the wiper going without him buying a new motor and linkages.. he rebuilt the motor ( i think) i saw him take the little motor apart and put it back together using a blow torch etc... he also took out the linkages and he found them seized once again on with the blowtorch and he lubed it up and got the wipers working.
but told me i might still need a motor after a while. but so far it works..( band aid fix)
on the way home from the mechanic 45 mins highway driving and up on a steep hill
i saw my temp gauge go to almost red 3/4 up and i got worried so i chugged it home without it going to red.. got home popped the hood and saw the reservoir full to the cap with brown garbage coolant... took out the reservoir and dumped it and put in some new coolant...
called a rad shop they wanted $75 for flush and cant be done till tommo
called jiffy lube $69 for flush and can be done now.
jiffylube is about 2km away from my place, while driving the car was getting to 3/4 again
i got it in jiffylube but once the mech tried to open the radiator, he called me out and told me he doesnt want to do it because it has so much pressure that i should take it to a special rad shop as he thinks theres somthing wrong, told him what happend and practically begged him to just do the flush and just let the car sit for an hr to cool down.
he came around and took a look at the upper hose of the radiator top part, and got that open without radiator exploding everwhere and from there he did the flush ( assuming pressure flush).
drove the car for about 50km without the needle going up more than half so im hoping that problem is solved.
ive only had this car for 3 days and ive already had my headaches
im hoping my cooling problem is solved. on saturday ill try to get the a/c working
the joys of buying a used car
