prob w 98 camry exhaust ---question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2005, 01:17 AM   #1 (permalink)
View sca676's Photo Gallery
Question prob w 98 camry exhaust ---question
Hi Guys,
got a question if any one can help great! My 98 camry 4cyl 2.2 has had a prob with the exhaust, sounded like a hole in the pipe (really loud), but the sound comes from the front of car, at times i can smell the exhaust fumes coming from vents,
when i went to leave my drive way today when i stepped on the gas i had only a little to no power with the engine, so i pulled back in . Does anyone have an idea as to what it is and how much it might run me to get repaired.... .
Thanks guys
Scott
sca676 is offline   Reply With Quote
Old 04-07-2005, 01:31 AM   #2 (permalink)
Moving Forward
View Cyorke's Photo Gallery
Sounds like it may be the a-pipe, header pipe whatever you want to call it. It is the first section of exhaust that is bolted to the exhaust manifold. could be a gasket or break in the pipe.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 04-07-2005, 05:48 AM   #3 (permalink)
View foompla's Photo Gallery
check your front mount and dog bone. If it is the front pipe - its very expensive.
foompla is offline   Reply With Quote
Old 04-07-2005, 06:30 AM   #4 (permalink)
ShawnM's Avatar
View ShawnM's Photo Gallery
Little or no power when you step on it means you probably have a restricted exhaust. Thats usually caused by the catalytic converter. A plugged up converter will also cause excessive back pressure which could blow out a gasket.
--Shawn
03 Camry LE
97 Lincoln MarkVIII LSC
67 Mustang
ShawnM is offline   Reply With Quote
