camry 92 xle sunroof problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2005, 07:26 PM   #1 (permalink)
View j1999t's Photo Gallery
I have a Toyota Camry XLE 1992 V4 w/sunroof
i am posting this on 4-10-05, the sunroof broke yesterday
what happened was , i was closing the sunroof after a drive home from the ACT test, and i am closing it and it doesnt close all the way, about 2 inches between the closing point
what can i do to fix this?
thanks
j1999t is offline   Reply With Quote
Old 04-10-2005, 09:02 PM   #2 (permalink)
Always Under Construction
View whocares04's Photo Gallery
i assuming ur motor is shot or somehow u blew a fuse...so check the fuse and if that's ok then download the 92-92 camry repair manual (or look in one u have) for the motor and test it's circuitry (it should tell u in the manual how-to) and u might end up having to replace the motor.
have u also tried it recently again...if not try to see if that works just so that u can close it or wait an hour or more...
that's all the info i got but u could also use the "search" function...
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
