uneven tire wear '94 camry
Hi forum,
My front tires are wearing thin on the inner edges. I believe the camber is off. If I view both tires from the front I can see that they almost have the same angular stance as a table chair. The only adjustable components are the tie rods for toe-in or out. After reading through the service manual, it states that if any caster, camber or steering axis inclination measurements are out of spec then I am to check for worn or damaged suspension components. My first thoughts were the ball joints may be worn as I've checked for bent components already. Has anyone had similar tire wear and if so, what remedied your situation? Thanks for all advise.
Troy
