GEN3 3VZ-FE Camry (busted cv boot, burnt off y pipe coating....) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-19-2005, 12:28 AM   #1 (permalink)
-=the wheel man=-
Killa_Kojak's Avatar
View Killa_Kojak's Photo Gallery
3rd Generation GEN3 3VZ-FE Camry (busted cv boot, burnt off y pipe coating....)
Hi Guys!
Well, after taking my car in for a oil change i found out that the cv boot has busted open exposing the drive axle naked to the free world and also the breaded metal surrounding the y pipe has burnt off .I was just wondering how long i could drive my car in this state since i am broke ass college student just trying to get by?
Car-
93 Toyota Camry V6 LE Sport
3MZ-FE-----4 Speed Auto
Killa_Kojak is offline   Reply With Quote
Old 04-19-2005, 01:54 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
very long. until the bearings fully grind down and then you can stilld rive, and until you have an emmisions test if the flex is leaking
terrastrife is offline   Reply With Quote
Old 04-19-2005, 02:16 AM   #3 (permalink)
Gameroom cash: $336825
iTrader Score: 14 reviews
View RichieRichJP's Photo Gallery
I think for quite a while (no longer than a year??) But I don't think it's very safe to do, cuz once it breaks, you're going to have a serious problem
RichieRichJP is offline   Reply With Quote
Old 04-19-2005, 02:23 AM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The exhaust won't matter. The CV joint, needs to be re-greased and have a new boot put on ASAP.
If you hear it clicking it needs to be replaced.
Cost differance between a CV joint, and simply buying a brand new axle, half-shaft is about $20.
FYI you have a 3vz-fe, not a 3mz-fe
My civic has had a clicking CV joint for two or three years, this ES has had one clicking for two.
"I'll replace the CV joint aaaaafter I put a turbo on the car". <- Words of a very smart person!
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 04-19-2005, 03:59 AM   #5 (permalink)
View 500KCamry's Photo Gallery
Change the boot before you need to change the joint. You'll need a few hours for a DIY.
Leave the pipe till you get a warning ticket. Use your $$$ for beer in the meantime.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 04-19-2005, 04:31 AM   #6 (permalink)
The Rent is Too Damn High
Deuce's Avatar
View Deuce's Photo Gallery
having replaced 2 of them:
i went 70k miles on a bad axle (pops and everything).
CV boot replacement, avg $220 in CA.
CV Half Shaft/Axle replacement, avg $160 in CA
here its cheaper to get a whole new axle than buying another boot. Check around up there in TO.
I don't need a sig, I'm 31.
Deuce is offline   Reply With Quote
Old 04-19-2005, 08:55 AM   #7 (permalink)
deviate from the absolute
Knailgun's Avatar
Gameroom cash: $231380
iTrader Score: 37 reviews
View Knailgun's Photo Gallery
you can drive it awhile like that...not reccomended though...the CV I mean
version 4.0 is here http://www.toyotanation.com/forum/sh...56#post3188156
Knailgun is offline   Reply With Quote
Old 08-01-2006, 12:16 AM   #8 (permalink)
permanent hiatus
ryuji16's Avatar
View ryuji16's Photo Gallery
axle costed me 150 installed. the difference is, the parts for the cv boot are cheaper overall, but you pay for the labor. usually a new axle install will only cost you a little more (or in some places, even less) because there is much less labor, PLUS you get a brand new axle instead of just the boot. its really a no brainer, i always just replace the whole thing.
and btw, the last axle i replaced, pretty much fell out when the mechanic went in to remove it. i was probably riding on it for about 7-8 months. but yes, you will be screwed big time if it breaks further while youre driving
three liters est. 1992
1.5 liters est. 2006
ryuji16 is offline   Reply With Quote
Old 08-01-2006, 12:23 AM   #9 (permalink)
permanent hiatus
ryuji16's Avatar
i just realized that this thread is from 2005. i forgot this came up in a search.
