Toyota Camry 1993 V4 short circuit problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-02-2005, 06:31 PM   #1 (permalink)
View steaua's Photo Gallery
Red face Toyota Camry 1993 V4 short circuit problem
I have a Toyota Camry LE 1993 4 cylinder ...short circuit problem. Wile driving today at a stop light the engine stopped working.I thought the coil went out so i changed both the coil and distributor cap, spark plug wires. Triyed to start engine again but ...it started run for about 3 min and stopped. Then i chacked the fuse box under front hood...and found fuse "AM2" burnd out....have change it but each time i try to start the engine that fuse "AM2" will burn...i have changed it several times and got same problem... Anyone encoutered a similar problem... a idea or little help will be great appreciated...
Thank you
Marius
steaua is offline   Reply With Quote
Old 05-02-2005, 06:38 PM   #2 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
You're likely running into a wiring issue (grounding most likely) somewhere in the circuit.
Just so you know, unless you've swapped in a motorcycle engine, this is an inline 4 cylinder, not a v4.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 05-03-2005, 12:08 PM   #3 (permalink)
do you have any idea what this fuse AM2 does?...somebody was relling me it might be the Neutral Safety Swich...?
any help appreciated...
Marius
Old 05-03-2005, 03:10 PM   #4 (permalink)
View karazy's Photo Gallery
The neutral sw/ runs off AM1. AM2 supplies the coil and igniter. It also works with the EFI, but there are smaller fuses in that system that should blow before AM2. I would look for a short in the coil/igniter circuit first. You may have got a bad replacement coil.
karazy is offline   Reply With Quote
Old 05-04-2005, 11:38 AM   #5 (permalink)
I have changed today the Neutral Safety swich and same thing..... the ignition coil its brand new,distributor cap allso new....
any other ideas ?...
Thanx
Marius
Old 05-04-2005, 02:41 PM   #6 (permalink)
I realize you are a noob, and you don't have to follow our advice, but when you totally ignore it and come back for more, it is very hard to understand why I should bother.
Old 05-04-2005, 04:49 PM   #7 (permalink)
View warlock's Photo Gallery
damn i always love it when i see V4
94 Scepter 1MZ-FE
< TN Type [R]ice Club>RICERS UNITE!! Join Type R..latest faction of TN!!
.....http://www.toyotanation.com/forum/sh...d.php?t=105457
warlock is offline   Reply With Quote
