1) Take off the panel where the outside mirror is at, 2) pry up the power window/door lock assembly and disconnect the harnesses, 3) pry open one filler cap on the side of the armrest and loosen the Phillips screw with a long screwdriver, 4) use the long screwdriver to loosen the 2 exposed holes that have the screws, 5) remove two exposed Phillips screws on the bottom, 6) pop out the clip near the front, 7) on the door side, push in the center pin and take the entire clip out, 8) lift up and out and the door panel should come off. To put back is the reverse.
Luc
1998 Camry LE V6 S/C
2006 RAV4 LTD V6 AWD
