98 Toyota Camry OEM Intake Manifold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2005, 04:32 PM   #1 (permalink)
View asheik9201987's Photo Gallery
What does a 98 Toyota Camry OEM Intake Manifold do exactally. also i f i get it what other equipment would i have to buy.
asheik9201987 is offline   Reply With Quote
Old 05-15-2005, 04:25 AM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
If you don't know what it is or what it does, you don't need it.
Air enters a engine like this: air filter --> intake piping ---> throttle body ---> intake manifold ---> cylinder head.
V6 has 2 intake manifolds (upper and lower). I4 only has 1.
http://www.autozone.com/servlet/UiBr...3d8013e9bc.jsp
Intake manifold from my 3S-FE:
"Skoolin' the unlearned!"
Old 05-15-2005, 08:20 AM   #3 (permalink)
Lex Zues!
RedPhoenix's Avatar
iTrader Score: 12 reviews
View RedPhoenix's Photo Gallery
How difficult was it to take off ( if you didnt take your engine out? )
Sold ^
Originally Posted by dysk8forlife
supercharger whine>girlfriend whine
RedPhoenix is offline   Reply With Quote
Old 05-15-2005, 10:17 AM   #4 (permalink)
Pissed
View Camryamnesty's Photo Gallery
hahaha
its fun....
Drain coolant, remove air cleaner hose label and detach any wiring harnesses lift the wire harness over the manifold unbolt braces,(who knew there were braces under the back of the manifold?)remove bolts hold in it on
this is out of my haynes manual, why you drain teh cooling system... ihav eno idea you could probably skip it but i dunno
Camryamnesty is offline   Reply With Quote
Old 05-16-2005, 04:15 AM   #5 (permalink)
Grenaded piston
88 LE's Avatar
Its not to difficult.
The hardest part is unbolting it from the cylinder head. Bolts/nuts are impossible to get to from the top of the car, so you have to unbolt it from underneath. This applies to a I4, its different on a V6 (you can unbolt both halves (upper and lower) of the manifold from the top).
You don't need to lift the wiring harness over the manifold. On a 3S-FE/5S-FE the wiring harness clips onto the front of the manifold.
And you don't need to drain the cooling system.
Old 05-16-2005, 05:09 AM   #6 (permalink)
Lex Zues!
RedPhoenix's Avatar
Yeah thats what I was talking about. Recommended from the underside of the car. Did you have it on a lift?
Sold ^
Old 05-17-2005, 03:56 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
Nope.
I removed the intake manifold with the engine in the car.
