Air Intake Install on 01' - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-20-2005, 09:29 AM   #1 (permalink)
View 5 Speed Camry's Photo Gallery
Unhappy Air Intake Install on 01'
Hello,
I have a 2001 Camry CE, and i recently bought an air intake for it. Its an offbrand one from Ebay and it comes with instructions, and i used some instructions i found in a forum link on here. Well i have some sort of sensor on the top peice of my sock air box (the peice that comes off). I do not know what to do with this sensor because it dosent plug into my new air intake as far as i can see, also can i get some help on how to install the intake correctly, help would be greatly appreciated. Thanks guys
Damien
www.cardomain.com/id/5_speed_camry
5 Speed Camry is offline   Reply With Quote
Old 06-20-2005, 03:52 PM   #2 (permalink)
View bassthrive's Photo Gallery
That sensor is your MAF - and it is very important. Sorry to be the bearer of bad news but the intake you bought is junk. Even if you got it installed somehow, it would most likely throw a check engine light. All hope is not lost though. With a little modification you can use it to replace the piping and resonator between your airbox and throttle body. here is how
now with 100% more clickability
bassthrive is offline   Reply With Quote
Old 06-20-2005, 03:59 PM   #3 (permalink)
View Ranger X's Photo Gallery
Are you sure he's talking about the MAF? I too bought one of those eBay short rams, and the sensor fit in just fine. But if it is the MAF, forget about running the car at all, because you can't bypass it as far as I know.
P.S. - As tempting as it may be, don't waste money on getting TVs installed in that car, unless you have just a ton of money laying around. Spend the money on something else that you'll enjoy more in the long run. If you really want to customize the interior, get something you'll actually use, like GPS or a better stereo. Just my two cents.
Ranger X is offline   Reply With Quote
Old 06-20-2005, 04:03 PM   #4 (permalink)
MAF is the only sensor i can think of located on the stock airbox. The only other things you'd plug into the intake are vacuum hoses. By the way, just realized its only a 4 cylinder, so disregard that link in my previous post, thats only for the 1mz's. Maybe you could post some pictures of the problem your having?
Old 06-20-2005, 05:24 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
That sensor is the IAT (intake air temp).
http://www.toyotanation.com/forum/t81698.html
"Skoolin' the unlearned!"
Old 06-21-2005, 07:49 AM   #6 (permalink)
Mitsubishi Diamante Owner
CDub LXi's Avatar
View CDub LXi's Photo Gallery
88LE is right.. gen 4 5SFEs don't have MAF
BTW, I like how this guy did his IAT:
http://memimage.cardomain.net/member...73_63_full.jpg
http://memimage.cardomain.net/member...73_64_full.jpg
CDub LXi is offline   Reply With Quote
Old 06-21-2005, 09:21 AM   #7 (permalink)
I printed out the tutorial that you guys gave me the link too, i didnt see the "sensor" i have, in that tutorial. Maybe im wrong but i will try to get some pics of it up here so you guys can see what i mean, thanks
Old 06-21-2005, 09:24 AM   #8 (permalink)
could you tell me what year the car is that is in the intake install manual. I donot see the sensor. And ive had 4 other people look at it and they all dont know..
thanks
Old 06-21-2005, 01:01 PM   #9 (permalink)
CDub LXi's Avatar
thanks
It's a gen4 (97-01) 4cyl. It's the same as my '01 CE is. If you can post the picture of the sensor you're talking about it would help a lot.
Old 06-21-2005, 05:53 PM   #10 (permalink)
Grenaded piston
88 LE's Avatar
Actually all 5S-FEs don't have a MAF. They use a MAP (manifold absolute pressure) sensor.
Look again.
^ The thing circled (lower circle) in green is the IAT.
^ Has electrical tape wrapped around it.
Old 06-21-2005, 10:12 PM   #11 (permalink)
CDub LXi's Avatar
I wasn't 100% sure on all of them so I didn't make a statement I didn't know to be 100% true. That's good info to know that no 5SFEs run MAF. I had MAF on my Altima... most intakes were just MAF adapters
Old 06-26-2005, 04:00 PM   #12 (permalink)
CDub LXi's Avatar
Okay 5spd.. if you're still checking in on this. I just installed my short ram on my '01 and the tutorials didn't show the way mine went in... I'll post a picture up soon of what was different. I still didn't have any problems installed the generic ebay intake though.
Old 06-27-2005, 08:52 AM   #13 (permalink)
Hello again guys.
Big Body....I keep checking up on this and i have EXACTLY the same car you have, except mines in 5 speed. I am the guy that you talk to on AIM sometimes. Would help alot if you could post them pictures up. Thanks
Old 06-27-2005, 12:33 PM   #14 (permalink)
CDub LXi's Avatar
In the tutorial (http://209.160.1.32/Intake/) I followed all the steps until this one:
Attach the other tube here, no clamp is necessary.
My '01 did not have that part.... this is where the other tube goes to on my '01:
The only problem I have with the new intake (which isn't really a problem.. it just kind of bugs me) is that it rest against my strut tower:
Oh well.. it works fine and hasn't gave me a CEL yet so I'm not going to worry about it.
I used electrical tape to plug the IAT for now. I'm going to do a better job on that soon.
Old 06-27-2005, 01:33 PM   #15 (permalink)
SoUtH fLa GeN 4
FDFL3131's Avatar
View FDFL3131's Photo Gallery
maybe dont buy from ebay?
FDFL3131 is offline   Reply With Quote
