stuck rear brake drum 95 Camry Wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-05-2005, 02:39 AM   #1 (permalink)
View petermiddleton's Photo Gallery
3rd Generation stuck rear brake drum 95 Camry Wagon
Car sat a few month E-brake was not on and now the rear left wheel is locked! I tried tapping the drum with a hammer but nothing else yet. Is there a star wheel adjuster to back off? I misplaced my manual but am downloading one now I hope will cover a 95. thanks in advance
Pete
petermiddleton is offline   Reply With Quote
Old 07-05-2005, 01:57 PM   #2 (permalink)
Gameroom cash: $274555
If it's like the generation 4 rear drum brakes (and it probably is) there is a star gear behind a rubber plug in the drum. Rotate the drum so that the plug is around 12:00 and the remove the rubber plug. The star gear should be just a bit to either side of 12:00 depending on which wheel you are working on.
There should also be 2 threaded holes in the drum to facilitate getting it off. You thread 2 matching threaded screws in these 2 holes and then turn them in as evenly as possible and it should lever off the drum. You will hear a pop when the drum breaks free.
Mike
Mike Gerber is online now   Reply With Quote
Old 07-05-2005, 02:08 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $127223
View Hajoca's Photo Gallery
Work on the "Star gear" shoe adjuster as far as possible first, the shoes may have cut a ridge into your drum.
Expanding the aduster is easy, so go as far as you can.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Hajoca is online now   Reply With Quote
Old 07-05-2005, 03:08 PM   #4 (permalink)
Don't forget about the generation 3 manual at the top of this forum. The brake section should give you a good picture of that star gear and it's location.
Mike
