97 camry idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-10-2005, 03:32 PM   #1 (permalink)
View sameer2601's Photo Gallery
Hi, i have a 97 camry 4cyl with a weard engine idle problem. The idle speed is normal most of the time but when the tranny is put on d the idle drops down a little and even more when the a/c is on but the engine never dies, and it comes to normal speed when the tranny is put back on n or p. it is more noticible during night time when the lights dims a little. the egr valve is operating normally and i even tried disconnecting it with no effect. is it the idle speed control valve or something else. please help
sameer2601 is offline   Reply With Quote
Old 07-10-2005, 03:50 PM   #2 (permalink)
HID/Retrofit Expert
white3ch0c0late's Avatar
iTrader Score: 7 reviews
View white3ch0c0late's Photo Gallery
It is normal for your idle speed to drop by 100-200 rpms when you switch into drive from Park. How much does it drop? Is it any more than about 100 to 200 rpms?
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
Old 07-10-2005, 05:58 PM   #3 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
does the engine shake alot what is you try cleaning the trottle body and the air intake plenumwith some trolttle body cleaner or some carb cleaner.
V6LE_CAMRY is offline   Reply With Quote
Old 07-11-2005, 04:25 PM   #4 (permalink)
i have already tried cleaning the TB with some effect . it was way too low before about 200 to 300 rpm sometimes and the a/c woudnt start but that was rectified after cleaning the tb . yes the engine shakes when put on d and a/c on. my friend has a similar make and model but his rpm stays normal whatever the situation. it goes down a little bit but returns to normal instantly. mine doesnt.
Old 07-11-2005, 05:29 PM   #5 (permalink)
V6LE_CAMRY's Avatar
Have you also replaced the distributor cap, wires and plugs? they may be worn. also put in some fuel injector cleaner, you may also have a cluought air filtrer. if not the probably your Idle Air Control motor may be going bad or your idle spped screw if any is incorrect.
keep us updated.
if you still need need help i will be glad to go thrugh my haynes manual
Old 07-11-2005, 06:48 PM   #6 (permalink)
johnnyzee's Avatar
View johnnyzee's Photo Gallery
lift the idle for a temporary solution on the throttle body (should be a screw to adjust it). could be a tps or air sensor. g'luck
johnnyzee is offline   Reply With Quote
Old 07-12-2005, 06:20 AM   #7 (permalink)
i will put some fuel injector cleaner today and then go for the screw. it still has the factory yellow paint on it . the spark plugs have been changed recently and there is no distributer . there are two separate coils with two plugs wire attached to each. my last option is to replace IAC after trying all the above suggestions .
Thanks a lot guys and will keep you all updated.
