97 Camry Remote Starter wire colors DIY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-29-2005, 11:03 AM   #1 (permalink)
View techrat's Photo Gallery
4th Generation 97 Camry Remote Starter wire colors DIY
Just installed one in my 97 , figured the info might be helpful.
+12 Volts = White or Black @ Ignition Harness
Ignition = Black/Red @ Ignition Harness
Accessory = Black/Yellow @ Ignition Harness
Starter = Red @ Ignition Harness
Tach = Black/Orange @ Instrument Cluster or Behind Glove Box @ ECM
Lock = Blue/White (mine was Light or Dark Green) @ Behind Drivers Kick Panel
Unlock = Blue (mine was Light or Dark Green) @ Behind Drivers Kick Panel
Doorpin = Red/White @ Fuseblock
Disarm = Red/Green @ Behind Drivers kick panel (If you have a factory alarm)
Brakeswitch = Green/White @ Brake pedal switch
Parklights = Green/Orange (mine was green) @ Fuseblock
>>> ALWAYS USE A GOOD MULITMETER TO TEST WIRES <<<<
Unless you have a "computer safe" testlight... don't use one.
Stay away from brightly colored wire loom, usually means an airbag wire
Solder all connections
Your car may have different color wires than stated above.
techrat is offline   Reply With Quote
Old 07-29-2005, 11:36 AM   #2 (permalink)
word to ur mother
lucanhookup's Avatar
View lucanhookup's Photo Gallery
i wish i knew how to install alarms. atleast this helps a little
lucanhookup is offline   Reply With Quote
Old 07-29-2005, 03:29 PM   #3 (permalink)
alarms are alot easier, if ya need help feel free to ask
Old 07-30-2005, 12:21 PM   #4 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Ok Techrat, I will take you up on your offer. I am planning to install a CrimeGuard 850i3 with Remotte Start and your help will be greatly appreciated. I have a Gen 3 95 Camry LE. I have all the specs and all.......you would not believe the prep i have put in so far......
Where to start....I have done most of the research.....
Can you please give me your email so I can start consulting.....
Thanks in advance. You might be a godsend....
my email: mandingpogi@comcast.net
mandyfig is offline   Reply With Quote
Old 07-30-2005, 06:31 PM   #5 (permalink)
email sent
