Originally Posted by 88 LE
Won't know till you tear it apart.
Depends on your skill and knowledge. Can't really say for sure.
Have you tore a motor apart or done a engine swap?
Well, The 3UZ is an iron block, so do iron blocks usually go bad with overheating? I'm just trying to find out if it's easy or not for this particular block to get damaged through overheating. I would just assume the heads are warped anyway.
I've never done an engine swap or worked on an engine before, but that's one of things I hoped to learn during this process.
The most involved things I've done before are front main seal/timing belt on a 2JZ-GTE and clutch/flywheel on a 240SX.
