'98 Camry tranny issue... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-18-2005, 08:51 AM   #1 (permalink)
View jermag24's Photo Gallery
Last week, I replaced the clutch on a '98 Camry, 4-cylinder. I took my time to do it right and everything went well. Yesterday, the right axle seal (at the transaxle housing) decided it was going to start leaking.
Has anyone replaced this? Is it a pain in the ass to do yourself? How much do you think someone would charge to replace this for me? Thanks guys, your advice in the past has prevented ALOT of headaches!
jermag24 is offline   Reply With Quote
Old 08-18-2005, 10:45 AM   #2 (permalink)
Has anyone done this? PLEASE help, I'm without a vehicle.
Old 08-18-2005, 11:20 AM   #3 (permalink)
View deekay140's Photo Gallery
You gotta remove the rear motor mount, unbolt the axle housing from the block and pry it away from the block pins and pound it off (once you disconnect the hub side). when reassembling, take some pliers, or a hammer and chisel and remove or break off the block pins. Once the pins are out of the way reinstallation is straight forward.
deekay140 is offline   Reply With Quote
