Here is a picture of the differential on a 94 V6 Camry Auto. Now...I found the drain hole, but now I cant find the fill hole as pictured in the haynes manual. It should be between the two futuristic fin looking things (see picture below) but its missing. So is the diff. filled through the regular trans. dip stick like the rest of the tranny? I thought the 94 had a seperate fill hole for the differential. But, this car had a rebuilt transmission put in, so its possible a newer transmission went in without the fill hole.
Anyway, can someone confirm that the differential will be filled along with the rest of the tranny?
btw: Yes, I unscrewed those two bolts on the side there, but I'm guessing neither one of those is the fill hole.
