Does anyone have 97+ S51 pics? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-10-2005, 05:44 AM   #1 (permalink)
View 91MR2quickNA's Photo Gallery
Hey guys,
I was just wondering if anyone had some 97+ S51 pics on hand. I'm comparing it to my 1991 S54, and I wanted to see the external differences, if any, on it. I'm looking for transmission options for my V6 swap, and with MR2 turbo hubs, axles (Camry/Solara intermediate shafts too), and E153s becoming rarer by the day, I just want something that'll make my life a bit easier.
The Camry/Solara I4 S51 is geared VERY similarly to the Camry/Solara V6 E153. There's some slight differences, but overall, it's extremely close. If the late model S51s are built like the S54s, then the only real weak point in the tranny is the differential. That won't be a problem for me since I don't plan on supercharging.
I'd really appreciate if you guys have any pictures of an S51 laying around. I'd need shots from all angles. You can e-mail them to me at jaybe@charter.net, if you need to.
Thanks
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 09-10-2005, 06:07 PM   #2 (permalink)
I'm a Mac
zoni's Avatar
View zoni's Photo Gallery
i believe the s51 was in the gen 2 camrys with 3sfe and s54 in all the 5sfe camrys...
Dave Zoni
Latest 3S-GTE Swap Pics
zoni is offline   Reply With Quote
Old 09-11-2005, 08:52 PM   #3 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
I have an S51 swapped in. I went with the S51 since the gears are a little shorter and I want to be faster off the line. I dont plan on pushing huge power so it should be fine. It was easier to do since you wont need axles, hubs, all the holes line up, no mixing of clutch components, and its easier to find.
Home Page: http://www.cardomain.com/memberpage/506928/1
5S-FE Turbocharged @8psi with 5-speed auto to manual swap
97camryman is offline   Reply With Quote
Old 09-11-2005, 09:47 PM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
i find at least a differetn e153 every couple of weeks on ebay, and the same ones over and over again for around 500-800
terrastrife is offline   Reply With Quote
Old 09-14-2005, 10:39 AM   #5 (permalink)
The S51 is used in all generation Camrys with the 5S-FE, and is geared a lot longer than the S54. The S54 would've created too much in cabin noise in a Camry/Solara for feasible use, even with a 3.944 diff. ratio. There was a misprint in the 1991 MR2 Service manual that accidently showed S51 instead of S54. My mom's 2000 Camry manual also shows the S51 is still in use.
..... 1st ... 2nd ... 3rd ... 4th ... 5th . Diff ratio
S51 3.538 1.960 1.250 0.945 0.731 3.944
S54 3.285 1.960 1.322 1.028 0.820 4.176 (also 3.944 overseas in some 3S-GEs)
Jason
1991 MR2 N/A (SW21)
