Tail Light Failure Sensor - NOT! - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 35 Old 05-14-2006, 08:52 PM Thread Starter
driftinco's Avatar
Quoted: 2 Post(s)
(Thread Starter)
3rd Generation Tail Light Failure Sensor - NOT!
Bought a 96 Camry V6 XLE with 72K miles...great car! but the tail light failure idiot light came on and stayed on even though the tail lights and brake lights all work. After some online research, I learned there is a tail light failture sensor in the trunk, driver side, near the trunk lid hinge. Found it. Ordered a new one as there are several models of sensors and it must match up with the VIN.
Ready for this? It was $212!! No luck with the local salvage yards either. Ah well. So I got it. Installed it. The dang idiot light still came on when the brake pedal was pressed. Hmmmm...
A little more online research led to finding that even though the lights may work, the bulbs may be worn enough that the sensor kicks the idiot light on. Fine. I drove to the grocery store, yes, it was late evening, and bought $2 worth of 1157 bulbs (one package). Wrestled them into the brake light sockets on the body, not the trunk lid, and the stink'n light still stayed on! Even with the new sensor installed. Fine.
So I dug the old one out of the trash and re-installed it. Guess what. That fixed it!!
It was $2 in bulbs not $212 in some electronic sensor that fixed the problem.
Moral of the story: Check the light bulbs first. It's worth the $2!!
driftinco is offline
post #2 of 35 Old 05-14-2006, 08:59 PM
VeeZed
JetspeedCamry's Avatar
Quoted: 0 Post(s)
Lol..well yeah, that would've been the first logical step....
Those sensors work on resistance of the bulb, not *Bulb Blown or Not Blown*.
As a bulb gets old, its resistance drops..and eventually even though its not blown yet, the sensor will pick up the low resitance and turn your idiot lights on. (Not really idiot lights in this case). Even a dirty contact, loose screw can cause low resistance/warning light..so yeah, always best to check all the bulbs, there fittings, there connections etc first.
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline
post #3 of 35 Old 05-14-2006, 09:30 PM
Quoted: 0 Post(s)
i have the same problem heres my solution
just ignore the damn light and havent spent a penny
2000 CAMRY CE
freestylez is offline
post #4 of 35 Old 05-14-2006, 11:04 PM
Quoted: 2 Post(s)
iTrader Score: 19 reviews
I have the same problem. Well, the passenger brake light kept going on and off at random times, replaced the bulb and found it had a bad filament. All lights work now, still get the warning light. It has something to do with them being aftermarket Ebay lights. I'll have to check ALL the bulbs
FOR SALE:|| Gen 3 & Gen 4 Performance Part-out!
MR2: 436whp-354lb/tq!!
RichieRichJP is offline
post #5 of 35 Old 05-15-2006, 06:45 AM Thread Starter
driftinco's Avatar
Quoted: 2 Post(s)
(Thread Starter)
3rd Generation
LOL, yeah, replacing the lights should be the first step. But dang, I grew up on a farm, and we didn't need some booger engineer's electronic sensing device to tell us when a light bulb isn't working. That's why I figured it was that electronic sensing device that was the problem, not the light bulbs. Ah well, live, learn and pass it on.
I'll get "Gus" (the car) cleaned up and some pictures posted soon.
post #6 of 35 Old 08-21-2009, 02:32 AM
Quoted: 0 Post(s)
I know this is a Camry problem, but I'm currently having the same problem on my Lexus SC300.
CrazySC300 is offline
post #7 of 35 Old 08-21-2009, 10:31 AM
Quoted: 1 Post(s)
Ditto: Changing bulbs worked for me.
Ditto, I had a similar experience. As far as I could see, all my brake bulbs worked. I replaced them anyway, and the little icon of a car with brake lights on was happy again.
Judge2 is offline
post #8 of 35 Old 08-21-2009, 01:21 PM
Stock? Blasphemy!
Gibson99's Avatar
Quoted: 9 Post(s)
i took the bulb out of the dash cluster. problem solved.
Gibson99 is offline
post #9 of 35 Old 08-22-2009, 12:14 AM
ConeKiller Camry
eyezack87's Avatar
Quoted: 3 Post(s)
iTrader Score: 7 reviews
I'm planning to either take the bulb behind the dash out or just to get the extra components to remove it from my custom LED brake light project going on. Black electrical tape is another option :P
1996 Beige Lexus ES300
2010 Blue Ribbon Metallic Camry LE
eyezack87 is offline
post #10 of 35 Old 08-22-2009, 06:31 AM
Proud Toyota Owner
CamryWilly's Avatar
Quoted: 0 Post(s)
On my old DX, all the lights worked, but when I removed the fogged up driver's taillight, I realised rust had soldered the bulb to the socket. Thank god that light never died so I went with the obvious dash cluster bulb removal.
CamryWilly is offline
post #11 of 35 Old 08-24-2009, 04:00 AM
Quoted: 0 Post(s)
For the record, My tail lamp failure sensor only tends to come on when I dim the lights to the lowest level on my cluster guage.
post #12 of 35 Old 08-24-2009, 10:50 PM
Hackchet
Quoted: 0 Post(s)
Just bought a Camry and wasn't too worried about the little backup light as I was aware of what the light meant. Thought it would just be a new light bulb. Turns out the previous owner for some unknown reason cut the wire harness where it splits for the trunk lid.
It cost me 30 min and a backache from bending into a weird position to re-soldier the stupid wires. At least the light bulbs still worked and thank heaven for color coded wires.
Hackchet is offline
post #13 of 35 Old 08-25-2009, 12:49 AM
Proud Toyota Owner
CamryWilly's Avatar
Quoted: 0 Post(s)
Ex-hidden hitch wiring?
post #14 of 35 Old 08-25-2009, 01:55 AM
bootcamper's Avatar
Quoted: 9 Post(s)
I have the same problem. It came on like 2 months back, at first it was really annoying. But now i have gotten used to it. I don't want to spent any money on this one until my next service.
Camry 99, V6 LE Black
bootcamper is offline
post #15 of 35 Old 11-10-2009, 08:37 PM
Quoted: 0 Post(s)
Good Moral -
I just changed one 1157 bulb in the rear and the longtime light went off immediately. More important many repairers with lot of experience could not resolve this problem for a long time and resolving it by myself gave lot of satisfaction.
davidnarayanan is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
