What are the signs of a failed Power-Steering pump? - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 3Likes
post #16 of 24 Old 02-16-2017, 09:38 PM Thread Starter
☻Black Member
Blackness's Avatar
Quoted: 248 Post(s)
(Thread Starter)
UPDATE:
Walp... I finally got to mess with the PS belt today during a standard 10,000 mile oil-change... I checked the belt deflection with the passenger tire off and it seemed a bit loose/stretched/oil/dry-rotted from age and the desert dryness... anyway... I pried on the adjuster to create more tension, then tightned the bolts back up -- and ALL FIXED! No more noiseses or 'choppiness' -- so in the end IT WAS JUST A LOOSE BELT...
Imma add a new PS belt for my wish-list for the next 10k oil change... Q: Does anyone have a Toyota part # for this belt or an OEM equivalent... I know Amazon has a Gates... lookin for OEM Toyota part is possible!
1995 2.2L Camry 5sfe engine
Blackness is offline
post #17 of 24 Old 02-16-2017, 09:42 PM
Moderator
Quoted: 429 Post(s)
Originally Posted by Blackness View Post
UPDATE:
I THINK...that the Bando offering is the OEM belt. It is on my Insight, but I haven't found definite evidence for Toyotas. P/N: 3PK760 for P/S on a '95.
I like both Bando and Gates, but I prefer Bando.
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k
00 Camry 5S-FE 187k
99 ES300 243k
01 ES300 151k
01 Insight 137k
insightbrewery is offline
post #18 of 24 Old 02-16-2017, 09:49 PM
Sr. Member (アンソニー ムクゴーアン)
mcgowaw's Avatar
Quoted: 910 Post(s)
glad you got it fixed blackness. thanks for reporting back and closing the loop for future searchers.
tony
1994 Camry, 1MZ-FE, A541E
2001 Sienna, 1MZ-FE, A541E
2006 Camry, 2AZ-FE, U250E
Give a man a fish......and you'll have one less fish.
mcgowaw is online now
post #19 of 24 Old 02-16-2017, 11:36 PM Thread Starter
☻Black Member
Blackness's Avatar
Quoted: 248 Post(s)
(Thread Starter)
Cool... looks like BANDO is made in Japan or OEM quality... so I will prolly go that route... it's a Camry... she's worth it!
post #20 of 24 Old 02-16-2017, 11:58 PM
Senior TN Member
Kingdom934's Avatar
Quoted: 923 Post(s)
I've heard Bando is what Toyota uses. I've used their belt. It's cheap and feels very solid quality. For the price of it, I'd replace it in a heart beat.
'85 Camry DLX 162K
'87 Cressida 78K
'04 Camry XLE V6 108K
'98 Camry LE AE V6 216K
'06 IS250 + sport pkg 131K
'04 Camry SE I4 5SPD 167K
Kingdom934 is offline
post #21 of 24 Old 02-17-2017, 10:44 AM Thread Starter
☻Black Member
Blackness's Avatar
Quoted: 248 Post(s)
(Thread Starter)
kewl! I'll go with the BANDO then - thanx for sharing your expereince with it!
post #22 of 24 Old 02-17-2017, 12:22 PM
Daijoubu's Avatar
Quoted: 37 Post(s)
Originally Posted by JohnGD View Post
I'd agree with others to check belt tension first. But I'd also make sure the crank pulley and the PS pulley are clean and dry. Use an old toothbrush and alcohol to clean the pulley grooves and allow to dry.
Yeah, these manually tensioned systems suck. Worse if it doesn't use a jackscrew like the alternator.
I'd use this tool, about $20: https://www.amazon.com/Gates-91132-B.../dp/B000CRDLZM
I was not able to tension it as per spec, it's impossible with the amount of room and the little leverage point you have to tension and tighten the bolt.
Daijoubu is offline
post #23 of 24 Old 02-17-2017, 12:40 PM
イリジウム
Quoted: 247 Post(s)
Yeah that's why I said the manually tensioned system really sucked, what a cheap design.
You have to use a pry bar carefully between the pump and engine block. It can be done so don't give up.
JohnGD is offline
post #24 of 24 Old 02-17-2017, 12:43 PM
イリジウム
Quoted: 247 Post(s)
Bando is what they are using lately. Dayco, Goodyear, and Mitsuboshi were OEM as well.
See if rockauto with shipping is still cheaper than O'Reilly or NAPA. I personally prefer Gates.
JohnGD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
