Stem Seals - How Distinguish Intake vs Exhaust..? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
 4Likes
  • 1 Post By BMR
  • 1 Post By insightbrewery
  • 1 Post By slavie
  • 1 Post By JohnGD
post #1 of 5 Old 02-15-2017, 05:16 PM Thread Starter
Quoted: 103 Post(s)
(Thread Starter)
1996 Camry V6 169,000 miles.
I've got this bag of 24 FelPro Stem Seals coming soon, photo posted below.
Apparently there are no instructions for distinguishing between the seals for the intake vs exhaust, is it possible to put the wrong ones in the wrong places..?
How can I distinguish between the two stem seal types..?
gaijin666 is offline
post #2 of 5 Old 02-15-2017, 06:01 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 674 Post(s)
I put FelPros in my 3VZ-FE, and it was obvious which was which. Exhausts were shorter and different colored.
Looking at the FelPro set in your pic and online, it doesn't look like the 1MZ uses different ones, exhaust Vs intake.
gaijin666 likes this.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
The Following User Says Thank You to BMR For This Useful Post:
gaijin666 (02-15-2017)
post #3 of 5 Old 02-15-2017, 08:19 PM
Moderator
Quoted: 447 Post(s)
If they're all together, they will fit either (all made to the higher spec, i.e., to withstand heat on exhaust side).
Careful, I've gotten private label wholesaler closeout Fel-Pros before (but for 5S-FE) that were not even the right size. 5S-FE Fel-Pro kit has two bags, one for intake and another for exhaust. Those are Viton (explicitly stated), but the SS72878 for the 1MZ just say "premium"...ideally you want Viton, much harder-wearing than rubber.
95 Camry 5S-FE 168k
95 Camry 5S-FE 125k
00 Camry 5S-FE 187k
99 ES300 243k
01 ES300 151k
01 Insight 137k
insightbrewery is offline
The Following User Says Thank You to insightbrewery For This Useful Post:
post #4 of 5 Old 02-16-2017, 01:10 PM
Senior TN Member
Quoted: 109 Post(s)
iTrader Score: 12 reviews
My felpro set came in felpro box with two different bags inside, explicitly labeled for intake and exhaust. I didn't actually check whether there was any difference. Got them from rockauto. Had an issue where the first box rockauto sent me did not contain felpro gaskets - somebody substituted them and returned. They sent me a new box with correct felpro seals and all was well with installation - the car no longer smokes on startup, and has been running well for a few months now.
slavie is online now
The Following User Says Thank You to slavie For This Useful Post:
gaijin666 (02-18-2017)
post #5 of 5 Old 02-17-2017, 12:52 PM
イリジウム
Quoted: 253 Post(s)
Rockauto still show the same for intake and exhaust for FelPro. But they also have intake or exhaust only. Wonder if they just changed packaging. Yeah we usually go Viton, but can't really tell.
I don't think any smart supplier is selling polyacrylate any more for these sludge monsters. But other makes do use fancy seals, like European premium brands use teflon seals at various places. Those hardly leak anything but require very precise fit. Don't think those will show up for Camry.
JohnGD is offline
The Following User Says Thank You to JohnGD For This Useful Post:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
