I purchased and driving my 1999 Camry 3.0 V6 for 2 weeks. I have changed the transmission fluid with Dexron 3 type. Nowadays, when the engine is cold there is no warning but after the engine warms (after 3-4 minutes), O/D off light starts to blink. The problems are also as follows:
- There is no problem about shifting all gears, the only problem is shifting from 3rd gear to 4th gear feels hard or rough.
- Even the car is driven at full throttle (kick-down), gear shiftings (from 1st to 2nd, 3rd, and 4th gear) occur at around 4000 rpm.
I did not do any diagnostic operations. What can I do first, now ? What may be the problems ?
I would see if there are codes stored in the ECU. I'm not sure if the blinking O/D will also mean there are codes stored for the transmission (I assume Check engine light is off). O/D blinking indicates usually a solenoid or wiring issue with the transmission.
Probably a bad shift solenoid, they are easy to change although you have to drop the pan...
I had a No 2 solenoid error for >5yrs and one day it went, with OD off flashing, shifting went wonky, put in a spare I'd got at the Picknpull ($0, pocket sized ) and it was good to go.
Thanks,i will check first the stored codes and solenoids. Is the problem that shifting gears at 4000rpm for full throttle related to same solenoid or wire problem also or is it a different issue ?
I did the diagnose for transmission and o/d off blink 7 & 3 times. "Code 73" occured. What does that mean ? I reached information about only codes 60,61,62,63,64 but nothing about code 73. Thanks everyone.
My A140E has the same blinking codes as you posted - no 73.
The A541E should have codes like OBDII. The FSM shows P0... codes, for example P0773 for shift solenoid valve SL malfunction. Maybe that's where you got 73
Yes, I have A541E transmission. Does the code 73 mean "Shift Solenoid E Problem" ? Is it the solenoid that just near the neutral safety switch on the transmission ?
Solenoid is underneath the transmission filter. You'll have to drop the transmission pan, transmission filter and the solenoid should be there. At least that was how my Cressida was.
How are you getting the O/D codes again? I recall getting the codes for an ODB I system requires jumping the diag box and the check engine light AND O/D light will begin blinking. If there are codes store, it will blink in a certain pattern.
ODB II system you are not able to read any engine or transmission codes without and ODB II reader, correct?
Yes, I did the jumping on the diag. box and o/d light blinks 7 & 3 times only. I have only the code 73. But, I don't know code 73 meaning and which corresponding solenoid in the transmission has malfunction.
Yes, I have a OBD diagnostic plug under the steering wheel but I have not a diagnostic device for it. I jumped the terminal on the diagnostic box under the hood, same as you mentioned above. And I get 73.
özgür selamlar kardeşim geçmiş olsun. yazdıklarını okudum ama tam özümsemek için bir de bana türkçe yazar mısın. ve sana neler tavsiye edilmiş. kendim okusam da tam emin olamıyorum. bende de 98 model var bilgi sahibi olmak adına sormaktayım.
Hi everyone,
After some time I have solved my problem of blinkind o/d off light. This was due to "Turbine speed sensor" and now everything is good but I have just one remaining and difficult to solve problem. When the engine & transmission is cold, gear shiftings are normal, however when it warms up to normal operation temperature, "gear shiftings from 1 to 2 and 3 to 4 " are very harsh/rough.
** There are no trouble codes stored. By the way, I have changed the transmission oil and filter.
This problem may be caused by solenoid(s), but I need to know which solenoid(s) in the transmission box ?
Thank you.
Related Threads
Ask a question
Ask a question
Toyota Nation Forum
6.2M posts
586.9K members
Since 2001
