2001 soft brake pedal problem - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 09-14-2006, 12:11 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Question 2001 soft brake pedal problem
Here is the deal: My mom's 2001 Camry LE developed a soft brake pedal over only about two or three days. Before that, the brakes felt fine. So I checked all the linings: plenty of pad and shoe material. Then I bled the brakes (RR LR RF LF). This was my first bleed so I'm only hoping I did it correctly. I went around to each corner twice. Still had a pedal that would go to the floor pretty easily. So I pulled both rear wheels and adjusted the little ratchet mechanism in there. Still got a low pedal. I don't see any leaks. Could it be that the booster push rod got out of whack? Also, I've seen posted in a few places that the brake system on this car may need to be bled diagonally, that is, (RR LF LR RF). Is this true? Is going around to each corner twice enough? It doesn't seem like a MC problem, but I could be wrong. I'm at my wits end here folks, and my Mom really needs her car and money's too tight to mention. Please, help.
Lunar Mist is offline
post #2 of 5 Old 09-14-2006, 02:47 AM
camry> /RAPES\ <honda
Jagwire's Avatar
Quoted: 0 Post(s)
Rear Drum Brake ( adjusting mechanism ) ?? try adjusting more.. if that dont work.. check your pressure release valve next to your brake fluid resivour ( or maybe the master cylinder is gone bad) .... check that release Valve
1998 Camry V6 5 speed
Red Tint,Viper Hood Ornaments
White
Camry 4 Life
Jagwire is offline
post #3 of 5 Old 09-14-2006, 05:54 AM
Quoted: 0 Post(s)
4th Generation
how did you go about bleeding
sounds like there is still air in the lines
solidg is offline
post #4 of 5 Old 09-14-2006, 08:27 PM
Senior TN Member
Quoted: 2 Post(s)
If you bleed and bleed and bleed some more and still have soft pedal, here are some other things that could cause it -
1. Maybe master cylinder needs to be bled too...if so, this often indicates a master cylinder on the way out soon
2. Sticky pistons in the front calipers, or rear wheel cylinders. These do not always manifest themselves as abnormal lining wear on one side, sometimes it is more subtle like the piston may be slow to return. May need rebuilt calipers OR wheel cylinders.
3. Worn or grooved, rotors or drums can cause this too.
marc780 is offline
post #5 of 5 Old 09-14-2006, 09:48 PM
5SFE
Lord_Anarchy's Avatar
Quoted: 0 Post(s)
Well, you don't really count anything when bleeding. What you ARE going for is a solid stream of fluid as opposed to it bubbling out or nothing coming out when you twist the bleeder nipple after pumping the brake pedal.
Can you run through your bleeding procedure? What did you do?
Lord_Anarchy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
