99 Camry Stalls After Warm Start - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 08-07-2007, 02:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I occasionally have the same problem as this lady here:
http://www.toyotanation.com/forum/ar.../169169-1.html
I noticed it about 4 years ago and it happened again in this last week. Thinking back, it seems to only happen around this time of year. Not sure if it is because we are travelling more, or the hot humid WV weather is doing it or what.
I don't think it is the IAC (But I'm not pro) as I do clean that out occasionally with some carb cleaner. I do that because it used to start yet idle real low with the possibility of quitting. I squirt some carb cleaner in the IAC at start and it opens right up and idles fine.
This only happens after driving for a while. At sometimes it will take quite a few attempts to get it to start again once it stalls out.
Thoughts, ideas?
RyanCamry is offline
post #2 of 3 Old 08-08-2007, 06:39 AM
Senior TN Member
Quoted: 426 Post(s)
Engine? I'm wondering if the car is flooding when sitting hot? Does it have a cold start injector? Anyway, try holding the gas pedal to the floor the next time it does not start and see if that helps. If it starts OK then I'd look for a flooding problem.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 233K
Stillrunning is offline
post #3 of 3 Old 08-08-2007, 10:22 AM
Quoted: 0 Post(s)
Thoughts, ideas?
same car sam problem before. It needs some clean up on IAC and Throttle body. There maybe some leakage on the intake air flow also. The regular carb cleaner is not enough. You need to take off some parts and hose to clean up and check. I did in a garage with $30 1 year ago, it never happened again.
zq_frank is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
