Squealing during acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 16 Old 09-22-2007, 08:32 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
4th Generation Squealing during acceleration
Im not sure where the sound is coming from... but whenever I accelerate or press on the gas, there is a squealing sound. The squealing sound subsides if I release the gas pedal, but continues when I push on it again.
Any thoughts as to where it came from?
1997 Camry LE
roastlechon is offline
post #2 of 16 Old 09-22-2007, 09:47 PM
Quoted: 1 Post(s)
maybe the serpentine belt? Does it squeal when you first start the car? Does it squeal when you rev the engine in neutral?
What acessories, if any, are you running when the squealing is present? Does it squeal if you accelerate hard in reverse?
Novice_cardude is offline
post #3 of 16 Old 09-22-2007, 09:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
It does not squeal when I start the car, nor rev engine in neutral. I have not tried accelerating hard in reverse, but no accessories.
post #4 of 16 Old 09-23-2007, 11:58 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
what is the serpentine belt btw
post #5 of 16 Old 09-23-2007, 12:21 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
...no serpentine belt on these vehicles.
There is a timing belt .... has it been replaced within 60k miles?
There are two accessory belts .... power steering and alternator. Have they ever been replaced?
What is the maintenance history of your vehicle? What is your vehicle?
former owner 98 Camry LE, 2.2L, automatic
54k miles, drop in K&N A/F, ... timing belt, water pump, NSS
dc_98_cam is offline
post #6 of 16 Old 09-23-2007, 12:39 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
i believe the timing belt has been replaced
my cars mileage is 140k and im not sure about the power steering and alternator belts
ill have to ask my mumsy
camry le i4 97
post #7 of 16 Old 09-23-2007, 12:55 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
Just a wild guess .... but there is a timing belt idler pulley, within the timing cover /belt assembly that has sealed bearings, which can wear out after high mileage.
Maybe try to listen with a stethescope or other sound device and locate the area of the noise as you rev the engine ... in park.
post #8 of 16 Old 09-23-2007, 05:41 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
interesting theory..
ill try it when i have time
post #9 of 16 Old 09-24-2007, 12:50 AM
Rubbish.
jsl222's Avatar
Quoted: 0 Post(s)
My friend had a similar problem on his 240sx. He said something about coolant leaking on the belt..?
jsl222 is offline
post #10 of 16 Old 09-24-2007, 03:24 PM
Quoted: 0 Post(s)
I am having a problem similar to this one. But it only happens very rarely, like once every 5 trips as a rough estimate. It only does it when I accelerate, but after I let off the gas and push down again it stops and never returns (until next time...).
Fredrick2003 is offline
post #11 of 16 Old 09-25-2007, 07:48 PM
Quoted: 0 Post(s)
i had the same problem, its definately the belt that runs the alternator (brain fart cant think of its name). it happened to me like 6 months ago. i tightened the belt and it kind of fixed it so i just replaced it and made sure it was tight. havent had a problem since. the old belt wasnt that old so my guess is that it just randomly got a cut or something in it somewhere lol
1997 Toyota Camry LE
JBL GTO 75.4II / 601.1II
JBL Power P650C (Front) MTX TDX6903 (Rear)
2 Cerwin Vega HED-10
n0rad is offline
post #12 of 16 Old 12-10-2010, 10:53 PM
Quoted: 0 Post(s)
I have this exact problem with my 1994 camry but it squeals when I have the heater on and am accelerating. Any thoughts?
JoeShmoe91 is offline
post #13 of 16 Old 12-10-2010, 11:29 PM
イリジウム
Quoted: 253 Post(s)
If it doesn't make noise in P/N, then it may be transmission related.
One of the things to check is ATF level and condition to see if it's low.
JohnGD is offline
post #14 of 16 Old 12-11-2010, 12:04 AM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
I would suggest checking for any leaks with a flash light and a piece of card board under car over night (if possible). belts love to squeal when wet...
JohnGD makes a good point about checking fluid in transmission. make it hot by driving lcoally for let's say 30 mins locally (since cold start in now cold weather) then on running car check fluid level (you may need to go through all gears on selector back and forth to make it accurate reading).
note the color (should be clear red/pink) and ... smell it also. if it stinks badly, prepare for a flush... soon.
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
post #15 of 16 Old 12-11-2010, 04:24 AM
Quoted: 0 Post(s)
Is there smoke rolling off the front tires when you hear the squeal ? If so it's your tires spinning making the squeal.
Solution: Stop hitting the NOX button or remove the super charger.
LOL...i couldn't resist!!
2005 white DC sport 4X4 Tacoma, bone stock...Toyhauler puller
2011 Camry LE..Traveler (also bone stock)
2000 Camry CE..workhorse (haz a gazillion miles on it)
1999 HD Electraglide..Wanderer (not bone stock)
az-yota is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
