How to remove inside rear view mirror? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 7 Old 11-06-2007, 11:15 PM Thread Starter
Senior TN Member
Tom 2000's Avatar
Quoted: 16 Post(s)
(Thread Starter)
I got a great deal on an auto-dimming mirror. It has a wedge mount, so I need to install an camlock adaptor to make it fit.
The problem is I can't figure out how to remove the factory mirror from the windshield base.
Anybody remove the insdie rear view mirror before?
Tom
2016 RAV4 Limited Hybrid
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is offline
post #2 of 7 Old 11-06-2007, 11:19 PM
97 Camry '8ball EDITION'
rebel8ball's Avatar
Quoted: 0 Post(s)
i would need to go check but most have a small alen head set screw on the mirror arm where it connects to the base, loosen and it should slide of... again im assuming thats how the camry is too....
rebel8ball is offline
post #3 of 7 Old 04-11-2008, 05:43 PM
Don't get mad. Get even.
El Tano's Avatar
Quoted: 0 Post(s)
does anybody know how to remove the OEM inside rear view mirror of a 98 camry ???????
No allen, no screw, just a little offset notch, and I try to get a little flat screw driver and pry but nothing...
Thanks
El Tano is offline
post #4 of 7 Old 04-12-2008, 11:01 AM
El Tano's Avatar
Quoted: 0 Post(s)
Anyone...I don't want to ending breaking the frickin' windshield...
El Tano is offline
post #5 of 7 Old 04-13-2008, 02:32 AM
El Tano's Avatar
Quoted: 0 Post(s)
anyone please
El Tano is offline
post #6 of 7 Old 04-15-2008, 12:05 AM
Quoted: 0 Post(s)
Tom,
Here is what my Haynes manual saids to remove the inside mirror.
"Pry between the mirror mount and the notch in the base of the mirror stalk with a screwdriver tip covered with tape. There is a hairpin-type spring holding the mirror stalk in the base. Push the screwdriver about 3/4-inch to release the spring."
Be careful and don't force it or you could crack your windshield.
I have not tried this.
Hope this helps.
George
kaplang is offline
post #7 of 7 Old 04-15-2008, 07:45 AM
Senior TN Member
bronzemaxell's Avatar
Quoted: 11 Post(s)
last time i remove my 97 camry rear view mirror, i recalled i used a very long and small screw driver, insert it in the notch hole at the base of the mount, push the screw driver in while move the base of the mount, it comes right off, you just need something long, narrow and strong enough to pry down the clip, it will come off. take a little patient tough.
bronzemaxell is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
ę Back
