2000 Camry transmission flush - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 11-22-2007, 08:54 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I've got a 2000 Camry with 70,000 miles on it, I'm considering having a transmission flush or drain and fill before winter. The car has never had either as far as I know. The service department suggests not having the flush due to the high mileage. The service department said a drain and fill would be ok. I've read comments about pros and cons of a high mileage transmission flush. Is there any truth to this? Any recommendations?
Thanks!
robob2 is offline
post #2 of 3 Old 11-22-2007, 11:23 AM
Embrace the Suck
Edmo83's Avatar
Quoted: 0 Post(s)
iTrader Score: 8 reviews
If you are comforatble getting under the car, and changing oil, i'd say, do about 3-4 drain and fills within a week. thatll be as effective as a flush. I did mines at 50K. and the car felt a little more peppy after it. i still drain and fill with every 4-5 oil changes.
If u want to try to do the flush, youll need a case of dexron III,, i use Castrol D-3 Synthetic) whatever u choose should b ok as long as its Dexron 3. You'll need a 10mm hex, and breaker bar, it can be hard to break it initially.
Also, a drain and fill only takes 2.5 Quarts at a time. Mines is a V6 however, if you have a 4 cyl, u'll need someone else to confirm that for you.
g/l on what u decide to do.
92 SC300 Garnet Red 5-speed 140k
01 Camry LE V6 Sailfin Blue 135K
08 MDX Tech Pkg Nimbus Grey 67K
Edmo83 is offline
post #3 of 3 Old 11-22-2007, 02:39 PM
Senior TN Member
Quoted: 10 Post(s)
Meh...........I say either one is fine. 70K ain't a lot of miles these days.
I'd probably just drain/fill. It's actually easier than changing motor oil since you don't do anything w/ the filter. Just drain/refill.
redgtxdi is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
