Final Answer? Castrol ATF - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 10 Old 01-06-2008, 04:16 AM Thread Starter
masteryota1's Avatar
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation Final Answer? Castrol ATF
Ok, so i got the garage stocked now with oil, filters, transmission fluid. I do all my searches on TN. One last thing (actually 2 things, but other is minor) I went to store after reading manual saying my 1995 V6 camry uses DEX II ATF. Me being a noob, i looked for exactly that, till i asked ok which one of these 2 ATF fluids would be what I needed then was told DEX III replaced DEX II.
Ok so i originally picked up Castrol IMPORT MULTI–VEHICLE I figured hey i know it was made in America, but made by TOYOTA. But when i got to the counter I was told If i used dex III that i needed thet Multi-Vehicle Domestic version.
So i took the advice and thats what i purchased, in fact i got 6 bottles of it.
Now earlier in the week I was reading on this forum and read somebody who said they used the Import Vehicle on their Gen 3 or Gen 3.5 camry on a recent drain and fill.
Ok so I am reading my bottle of Domestic multi vehicle ATF AND IT mentions DEX III. but on their import multi vehicle it mentions Toyota nissan etc. and something called DEX III H, AND some other stuff
BEING new to this, I hate the idea of screwing up badly on my first time around at this. WHICH one is the correct fluid? do they both contain what is recommended? Should i say SCREW CASTROL period and just get something like valvoline that just says ATF on the bottle and dex III?
here is the link to castrol site with the info they list. SORRY FOR THE BOOK on such a simple subject
http://www.castrol.com/castrol/secti...tentId=7024042
Castrol Multi-vehicle Domestic
Castrol Mutli-vehicle Import
masteryota1 is offline
post #2 of 10 Old 01-06-2008, 09:27 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
bump
post #3 of 10 Old 01-06-2008, 10:57 AM
Kep
Senior TN Member
Kep's Avatar
Quoted: 2 Post(s)
I don't have an answer for you. However, Castrol is offering both products so they should give you an unbiased opinion. There is a "Contact Us" tab at the top of that link that you gave us. Cut and paste your original post to them and see what they say. Post it back here. We'd be interested also.
Kep
Kep is offline
post #4 of 10 Old 01-06-2008, 11:45 AM
Quoted: 0 Post(s)
I drained and refilled my AT with Valvoline dextron/mercon ATF. So far no hiccups.
wahed3001 is offline
post #5 of 10 Old 01-06-2008, 05:02 PM
'93 LE Wagon V6 '94 LE I4
Quoted: 29 Post(s)
OP,
Use the fluid that says Dexron III on the label.
DFBonnett is online now
post #6 of 10 Old 01-06-2008, 05:32 PM
Owner of much Obsolete
Jeff Lange's Avatar
Quoted: 7 Post(s)
I would stick with the Domestic Multi-Vehicle ATF, it appears to basically be Dexron III with some additives. Import Multi-Vehicle ATF does say it meets Dexron III standards as well, but seems to be more tailored for the newer vehicles that use stuff like the Toyota Type T-series, etc, which is not what your transmission calls for.
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
1993 Toyota Previa 5MT Studded Ice Race Van
Jeff Lange is offline
post #7 of 10 Old 01-06-2008, 05:43 PM
Senior TN Member
Tom 2000's Avatar
Quoted: 16 Post(s)
I changed the transmission fluid in my Maxima last month. I bought 4 quarts of the Castrol import multi-vehicle ATF at Autozone, then realized I was 1 quart short after I drained it. The Schucks Auto Parts I went to only had the Castrol Domestic multi-vehicle ATF, so I bought it.
I've been driving my Maxima regularly since then and it shifts nice and smooth.
I bought 5 more quarts of the Castrol Import Multi-Vehicle ATF recently and plan to drain/refill the differential & the transmission on my Camry.
Both my Maxima and Camry call for just Dexron III (an older standard) and either the Castrol Import or Domestic Fluid should work just fine. If I had a newer late-model car that calls out for a higher standard like T-IV, then I'm sure I'll stick with the Import Multi-Vehicle ATF.
I did notice the import fluid was a little more at $3.99. The domestic fluid was $3.19
Tom
2016 RAV4 Limited Hybrid
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now
post #8 of 10 Old 01-06-2008, 10:54 PM
How hard can it be?
BlueFusion6851's Avatar
Quoted: 0 Post(s)
Thanks for finding this out, I'll definately use the Castrol Dextron III when I flush my transmission.
2006 Pontiac G6 GT (177,000 miles)
1992 V6 XLE Camry (204,000 miles) Free Project Car, Just needs headgaskets
BlueFusion6851 is offline
post #9 of 10 Old 01-11-2008, 12:59 PM
Quoted: 0 Post(s)
Final Answer by Castrol US Employee
Hi masteryota 1 -
I am a Castrol US employee at our headquartes in Wayne, NJ. Dexron II is an older specification which has been replaced by several newer specs, including Dexron III and Dexron III H. Both Castrol Import Multivehicle ATF and Domestic Multivehicle ATF may be used in your vehicle, as they are both backwards serviceable to Dexron II.
Hope this helps!
BSteidle is offline
post #10 of 10 Old 01-11-2008, 02:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Originally Posted by BSteidle View Post
Hi masteryota 1 -
Hope this helps!
THANKS, everybody glad to know i am not the only person who benefits from my off the wall questions lol
The Following User Says Thank You to masteryota1 For This Useful Post:
speedkar9 (05-09-2014)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
« Back
