'93 v6 ignition timing question - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 12 Old 01-05-2009, 11:44 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hi all,
I have a '93 V6 3VZ engine and want to check the timing. The shop manual says I should use "#4 high tension wire" for timing. I presume this to mean the #4 plug wire. I've never heard of this before! I though all engines base ignition timing from #1 plug.
Should I be using #4 or #1 plug for checking timing?
Thanks,
Greg
gjz30075 is offline
post #2 of 12 Old 01-05-2009, 04:53 PM
Quoted: 0 Post(s)
3rd Generation Use #1 cylinder for ignition timing
Hey there greg,
use the #1 cylinder for checking/adjusting the ignition timing. This is the rear cylinder on the far left while looking under the hood, and facing the fire wall. (Closest to the wiper motor). Warm the engine to normal operating temp, and shut it off. Place a jumper across T1 and TE1 of the Data link connector under the hood, and re-start the engine. The check engine light and O/D off light should flash at a steady rate, and the idle may seem a little low and rough (this is normal). point your timing light down at the timing marks and read where they are. The proper timing for this engine is 10 deg. advanced (BTDC). Adjust the timing by rotating the distributer left or right a little at a time until the desired timing is reached. NOTE: There are 2 distributer hold down bolts on the distributer. one toward the front of the car and one at the bottom toward the transmission-this one is hard to see, so you will have to "feel" the wrench over the head of the bolt. re-check the timing after you completely tighten the distributer as it may shift while tightening. with the engine running, point your timing light at the timing marks then watch the timing advance to approx. 20 deg. or more when you remove the jumper from T1 and TE1 of the data link connector. you will notice the idle come up and smooth out. FYI: If you want to improve the performance of your Camry, try setting the ignition timing to 20 deg. advance (BTDC) instead of 10 deg. You should notice a considerable improvement in overall performance, Though you will HAVE to burn HIGHER OCTANE pump gas, Supreme or Premium grade. (This is necessary to prevent Pre-ignition, which CAN damage your engine) Pre-ignition will make a "tinkering" sound most noticable under hard acceleration or heavier loads such as climbing hills or while passing. Pre-ignition CAN damage your engine, so be carefull. I have a '93 v-6 Camry 3VZ-FE, and I have run mine at 22 deg. advanced for a year now, (Premium ONLY, running regular pump gas is no longer possible) and all is well.....BUT DO SO at YOUR OWN RISK!
camry6 is offline
post #3 of 12 Old 01-05-2009, 07:01 PM
VVT-1MZ + ES5spd
Bdub215's Avatar
Quoted: 9 Post(s)
agreed. usually the timing is set as conservative as 7-8 degrees. i suggest setting to 16-17 degrees advance and lean the AFM cog 2-3 clicks. Premium is a must though
93 Lexus ES300 5spd I/E URFSB URRSB
01 Toyota Avalon TFSB, Weapon-R, Whiteline, Fogs
Bdub215 is online now
post #4 of 12 Old 01-05-2009, 08:31 PM
Quoted: 0 Post(s)
Air Fuel Mixture cog?...2-3 clicks?...does this apply to '93 Camry v-6 3vz-fe?...Please..enlighten me.
camry6 is offline
post #5 of 12 Old 01-06-2009, 12:20 AM
just a nobody
Quoted: 118 Post(s)
You can use #4 plug wire because it is easier to get to them #1, it is exactly 180 degree opposite to #1 cylinder on the distributor, so the timing mark would be the same as #1 cylinder. And it is the companion cylinder to #1, the forth in the firing order, both pistons are on TDC at the same time, one is at the end of its compression stroke while the other is at the beginning of its intake stroke.
N.E.O.
new echo owner is offline
post #6 of 12 Old 01-06-2009, 03:13 AM
engineer in training
Quoted: 0 Post(s)
Only the 3vz has a flap type airflow meter so yes.
Search for Toysrmes cheap mod series and you will find instructions for adjusting the AFM.
Luckynumber5 is offline
post #7 of 12 Old 01-06-2009, 12:14 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks guys!
gjz30075 is offline
post #8 of 12 Old 04-26-2011, 08:43 PM
Quoted: 0 Post(s)
Subscribing.
Roach
roach4047 is offline
post #9 of 12 Old 06-13-2011, 12:32 PM
ex tech, new driver
Quoted: 0 Post(s)
Odd timing
Had to replace the front main seal and water pump. I had moved everything while trying to take off the front pulley. Like some other post, I had multiple white out marks and half wiped off. I set the cams to the marks and lined up TDC on the 0 mark. After putting everything back together, it starts up fine. It does run rough and I hit the stops when trying to adjust the timing. I can not adjust it any further. I have looked at the marks and they still look good. Any ideas?
93 Camry V6 3.0 224K+ miles, at least 3rd hand gonna tinker on this for a while
zorcy is offline
post #10 of 12 Old 06-13-2011, 05:51 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 675 Post(s)
Maybe the timing belt is off a tooth on the rear bank's exhaust cam? That one drives the dizzy, so maybe that's why you're running out of spark timing adjustment??? Just a wild guess.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #11 of 12 Old 06-13-2011, 09:32 PM
Quoted: 0 Post(s)
The cam cogs have to go in a certain way, one faces out the other faces in if that makes any sense. If you are off a few teeth which is likely, the distributor will not have enough adjustment to set the ignition timing. You need to recheck the cam gears.
post #12 of 12 Old 06-14-2011, 06:50 AM
ex tech, new driver
Quoted: 0 Post(s)
Cam Cogs
Funny you mentioned that. I had reversed them on first assembly, left and right banks, and had to swap them out. Seems they rub hard against the belt cover if they are wrong. I will take it apart again and check, thanks.
zorcy is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
