Engine "sputters" when accelerating - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 13 Old 05-05-2009, 12:27 AM Thread Starter
whip_cracker's Avatar
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation Engine "sputters" when accelerating
Hey guys,
Was on a cruise yesterday with SupaTouring and A yesterday and came across a weird problem...
When in 4th gear (overdrive on my Auto) on a 3VZFE engine, and put the foot on the throttle, I get this sputtering noise, sporadic... drops the acceleration when it does it too... it can sputter when driving on a flat road, or going up a hill. It can do this "sputtering" noise 5 times a second no problem. It gives you the feeling that it could be bad fuel not burning correctly or something.
I've used 98 octane V Power in this for quite some time... the only thing that myself and a couple of others think it could be is either fuel filter, dirty injectors or maybe even the timing being out... maybe even bad fuel. I'm not 100% sure but the mechanic reckons to change the fuel filter in the engine bay first and see if that helps... then to go looking down the lines of getting the injectors cleaned.
Anyone got any ideas? It didn't happen when idling in P, but I noticed this morning when pulling outta the driveway and sitting the car waiting for the garage door to close, the car sputtered a little bit... has been happening for the last day or so, slightly noticed it Wednesday/Thursday after I filled up.
Thanks lads
whip_cracker is offline
post #2 of 13 Old 05-05-2009, 03:42 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Ay lads,
Looks like it's stepped up a notch... the "sputter" is now constant, every 1/2 second it does it... my car now sounds like a freakin WRX with the exhaust and all! Hahahahaha
I had my uncle have a check... he reckons one of the cylinders might not be firing due to a bad spark plug...
Any other ideas? Adam? One of the American bros help out an Aussie :P Hahaha
Thanks
post #3 of 13 Old 05-05-2009, 05:20 AM
deviate from the absolute
Knailgun's Avatar
Quoted: 1 Post(s)
iTrader Score: 43 reviews
check the distributor and wires for any condensation, the seal might have also gone on it.....mine did that same thing once upon a moon
Originally Posted by TrailDust View Post
Even his avatar is cool. He's setting a standard for manning-up here....
I'm thinking, if Knailgun had been surprised by this display it'd probably have 15 holes in it and laying limp on the floor.....
Knailgun is offline
post #4 of 13 Old 05-05-2009, 06:30 AM
Quoted: 98 Post(s)
iTrader Score: 16 reviews
Shannon, I'd agree with ^. Start with the cheap stuff 1st.
Also, my Parent's old '87 Nissan Sentra did the same thing and it turned out to be the fuel pump on it;s way out, and would the car would sputter under load due to not enough fuel.
Does this only happen at higher speeds?
My Camry: http://www.cardomain.com/ride/228043...y-xle-sedan-4d
'96 Camry: 2MZ
'95 AE101: JDM Tails/Grill/BiXenon Headlights. JDM Lighted Ignition Keyring and Cabin Air Filter
ASG14 is offline
post #5 of 13 Old 05-05-2009, 08:40 AM
Lost to follow up!
Quoted: 1 Post(s)
iTrader Score: 59 reviews
Adam it sound kinda like what was happening to Heathers 5sfe when I changed the wires.
eyeball96 is offline
post #6 of 13 Old 05-05-2009, 01:14 PM
'93 LE Wagon V6 '94 LE I4
Quoted: 29 Post(s)
It could well be failing ignition components such as plugs, wires, cap, and rotor. What is the condition/age/mileage on these?
DFBonnett is offline
post #7 of 13 Old 05-05-2009, 04:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Has 172k on the clock... not sure what that is in Miles? Maybe 110k Miles...
Adam, it's happening all the time now... there's a chance that it's the dizzy, being that there's a VERY SMALL oil leak with it, but it's been like that since I bought it 2-3 years ago with 117k on the clock... every service you just need to get a cloth to wipe away the oil. If the oil was building up in the dizzy, I'd be worried for sure though!
I've been told by many that it could be the plugs... can only see though ay! I haven't had to touch the plugs yet because apparently the plugs are meant to last around 100k... apparently that's "bullsh!t" according to my uncle... lol (my uncle's the kind of racecar driver that will have him and his team swap an engine in a buggy in a couple of hours... absolutely nuts.
Thanks guys, I'll keep those other things on the list to check too :P
post #8 of 13 Old 05-05-2009, 04:21 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Quick question,
Can anyone recommend a type of plug I should be after?
Adam suggested once some NGK Iridium Spark Plugs.. if not, the Denso Platinums straight from Toyota.
Thanks guys
post #9 of 13 Old 05-05-2009, 04:24 PM
Quoted: 98 Post(s)
Shannon, if you can wait a couple weeks I can get it all here and ship it if there is a large difference.
'96 Camry: 2MZ
ASG14 is offline
post #10 of 13 Old 05-05-2009, 05:15 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I'd like to see this car run for two weeks... hahaha. When you have this sorta "boxer engine" noise you know you want it sorted ASAP. What a royal pain in the arse it was a few mins ago driving to work... bloody hell!
There a P/N that I should be looking for mate?
Thanks ay..
post #11 of 13 Old 05-05-2009, 05:26 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Maybe this Part Number?
NGK Iridium: BKR6EIX-11?
post #12 of 13 Old 05-05-2009, 05:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hang on...
BCPR6EIX-11? Apparently the one I mentioned before was for the 4 bangers... this P/N is for the 6 cylinders... apparently the thread's different as per SuperCheap Auto (one of Aust's biggest Auto shops... not exactly the cheapest either).
Thanks lads
post #13 of 13 Old 05-06-2009, 03:51 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
UPDATE:
Was a spark plug in the front bank on the right. Replaced it and workin like a dream. Replaced the front bank with the NGK Iridium IXs and will be replacing the rears next week by the mechanic. Took one look at it... and went "nope, some other poor barstard can do that!" hahaha
Thanks lads
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
