Replacing Struts - Do I need New Mounts? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 9 Old 06-15-2009, 09:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello Camry fans,
I am replacing all four struts on my 1997 Camry LE 4-cylinder. I am thinking of going with Monroe Quick Struts because they are priced reasonably and for a few extra bucks, I don't have to gather all of the individual parts and buy a spring compressor. But I am open to other opinions or recommendations.
I have a few questions:
1. Do the quick-struts come with new mounting gear? The Monroe website description says that it has everything you need to swap out your struts, but it doesn't specifically mention the mounts.
2. Is it always necessary to replace the mounts? The car has 160,000 miles on it, almost all of which were acquired in Illinois (i.e. rough weather).
3. I've seen strut boots for sale - are these necessary? I can't believe it's almost $100 for four of little rubber boots! e.g. These guys: http://c2c.activant.com/ctoc/index.j...NGVRpwBFIIXj0A
Thanks for any help or advice!
-The Dude
The_Dude_1991 is offline
post #2 of 9 Old 06-15-2009, 09:35 PM
Quoted: 98 Post(s)
iTrader Score: 16 reviews
It;s not 100% necessary, but it's 100% recommended.
The Monroe quickstruts will come with them. Mount, bearing (for front mounts), struts, and rubber parts. It's a complete bolt in unit.
My Camry: http://www.cardomain.com/ride/228043...y-xle-sedan-4d
'96 Camry: 2MZ
'95 AE101: JDM Tails/Grill/BiXenon Headlights. JDM Lighted Ignition Keyring and Cabin Air Filter
ASG14 is offline
post #3 of 9 Old 06-15-2009, 09:40 PM
Quoted: 0 Post(s)
I always recommend people change the strut bearings when replacing there struts.
It's relatively inexpensive and saves you a lot of hassle in the long run.
Same goes with buying New sliders when doing a brake job
Default User is offline
post #4 of 9 Old 06-16-2009, 07:35 AM
mixed bag 'o vehicles
ghettosled's Avatar
Quoted: 6 Post(s)
man, if the monroe quick struts already come with the mounts, not only is it easier to replace, but probably cheaper. here is what i was quoted at napa
each front strut $77
" "mount $89
" rear strut $67.50
" " mount $41.47
grand total of $550. i have no idea why the mounts are more than the struts themselves.
ghettosled is offline
post #5 of 9 Old 06-16-2009, 01:04 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
" "mount $89
" rear strut $67.50
" " mount $41.47
ha - yeah, the pricing on this equipment doesn't make a lot of sense. How can a complete quick strut go for $150, but a cheap little mount kit costs over $50? (at the store I visited)
Thanks for the advice everyone. I've never done shocks/struts before, but I enjoy working on my cars so I will give the quick struts a shot.
post #6 of 9 Old 06-16-2009, 02:20 PM
Quoted: 85 Post(s)
Yes, on the 97-99 Camrys always replace the upper strut mounts when changing the struts. They were a known trouble area on these year Camrys that can cause a rattle when going over bumps. I have been a strong supporter of the Monroe Quick Struts as an all inclusive replacement, especially to eliminate a rattle in the suspension when going over bumps. No guess work on what to replace to eliminate the rattle. Everything that can cause the rattle in the strut assembly is now new. Where did you find them for $150? That's pretty cheap. I used the Quick Struts to replace the rears on my 98 about 3 years ago and the cheapest I could fine them for back then was $179 at Pep Boys.
Mike
Mike Gerber is offline
post #7 of 9 Old 06-16-2009, 04:05 PM
Quoted: 0 Post(s)
Quick struts come with mounts.
The front ones have a set of bearings and they do wear out. The rear does not have bearings and probably does not need replacing.
Where are quick struts for $150? Best price I've seen is in the $200 range. for Monroe Sensatracs.
flyeri is offline
post #8 of 9 Old 06-16-2009, 05:26 PM
Quoted: 98 Post(s)
Prices below are form Rock Auto, and they have a 5% discount code for TN users.
MONROE Part # 171681 {Quick-Strut; Incl. New Sensa-Trac Strut; Coil Spring; Bearing Plate; Insulator; Boot Kit}
Rear Left
$161.79 $0.00 $161.79
MONROE Part # 171680 {Quick-Strut; Incl. New Sensa-Trac Strut; Coil Spring; Bearing Plate; Insulator; Boot Kit}
Rear Right
MONROE Part # 171679 {Quick-Strut; Incl. New Sensa-Trac Strut; Coil Spring; Bearing Plate; Insulator; Boot Kit}
Front Left
$167.89 $0.00 $167.89
MONROE Part # 171678 {Quick-Strut; Incl. New Sensa-Trac Strut; Coil Spring; Bearing Plate; Insulator; Boot Kit}
Front Right
'96 Camry: 2MZ
ASG14 is offline
post #9 of 9 Old 06-17-2009, 01:38 AM
イリジウム
Quoted: 247 Post(s)
Yeah, buy parts can cost more than getting a complete assembly. A Monroe mount plus a Monroe strut cost just about the price of a Monroe QuickStrut.
JohnGD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
