Toyota Camry gen 4 Wet Floor - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 06-16-2009, 10:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
4th Generation Toyota Camry gen 4 Wet Floor
A couple of weeks ago, I noticed that the rear right footwell on my camry was soaking wet(after it ruined a $60 textbook). I checked the a/c condenser line and it was clean. I checked the sunroof lines by pouring water from a squirt bottle into each of the four corners of the rails and water came out the respective hoses. I pulled up the floor and checked the body plugs, cleaning them and then replacing them. After I replaced them, i put silicone sealant around the edges of both the front and rear passenger body plugs. Today, I find the same problem after its been raining for awhile, the right rear footwell is soaked and the water has started to creep up a few inches into the front passenger footwell.
I'm out of ideas, Any suggestions?
hgrimberg01 is offline
post #2 of 3 Old 06-17-2009, 01:24 AM
all my heros are evil
cykaaro's Avatar
Quoted: 0 Post(s)
Have you checkd around the windsheild for leaks at all? Had a big leak on my jeep that you couldn't tell it was there until it was raining and water was seeping in.
Good luck
cykaaro is offline
post #3 of 3 Old 06-19-2009, 08:19 AM
Quoted: 0 Post(s)
I had a friend who had the same problem... the drains which leads the water from the roof of the car and to the bottom (over the tires)... that drain was blocked so all the water that was suppose to be drained on to the road was seeping into the right passenger side floor.
ruffryder876 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
