Denso or NGK? Spark Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 36 Old 09-14-2009, 01:00 AM Thread Starter
Micky Blue
Mickyblue's Avatar
Quoted: 6 Post(s)
(Thread Starter)
3rd Generation Denso or NGK? Spark Plugs
I'm looking at the Denso IK20 Iridium for my 1996 camry 5SFE, or NGK Ix-Iridium. The NGK is like 8 bux cheaper than the Denso yet i hear Denso's are better for toyotas... Now im just being a cheap scape, but i also like to be well informed, Does anyone know the difference between these two plugs or could show me the different because i cant find anything on them
Mickyblue is offline
post #2 of 36 Old 09-14-2009, 01:22 AM
イリジウム
Quoted: 259 Post(s)
The NGKs, IMO, are better plugs than Denso. Get the NGK Laser Iridium. This 0.7mm iridum tipped plug has a platinum ground pad and should last the 120K mile spec'ed interval.
The IK20 however, is just a regular shorter life plug without the ground pad. You'll get less iridium and less platinum than NGKs in general. However, one advantage is the slightly thinner center electrode (0.4mm) but probably with a shorter life than the 0.7 mm spec'ed for Toyota.
Ahhhh, see the following FAQ from Denso:
"Toyota models carry an ultra long-life Iridium plug variation (.7mm with platinum tipped ground) that is capable of up to 120,000 miles of service. DENSO Iridium Power plugs, with their .4mm center electrode, have been developed for performance applications. Because gradual wear will “round-off” firing points over time, the concentrated firing power and voltage requirement benefits will be reduced. For this reason, DENSO advises replacement after 30,000 miles."
http://www.densoiridium.com/faq.php
JohnGD is offline
post #3 of 36 Old 09-14-2009, 01:27 AM Thread Starter
Micky Blue
Mickyblue's Avatar
Quoted: 6 Post(s)
(Thread Starter)
k, whats the difference between the IX iridium vs the Laser iridium?
post #4 of 36 Old 09-14-2009, 01:27 AM
Proud Toyota Owner
CamryWilly's Avatar
Quoted: 0 Post(s)
Denso.
The BEST for everything that's
1)Asian
2)Uses Internal Combustion
CamryWilly is offline
post #5 of 36 Old 09-14-2009, 01:38 AM Thread Starter
Micky Blue
Mickyblue's Avatar
Quoted: 6 Post(s)
(Thread Starter)
Im so confused
post #6 of 36 Old 09-14-2009, 10:49 AM
D.I.Y.'er since 2004
DxElite's Avatar
Quoted: 0 Post(s)
+1 for JohnGD's explanation on that.
Add on that the Denso IK20 are and the NGK IX are designed for performance, like an upgrade but you don't really get more ponies. Mainly you get "efficiency, durability, and improved firing power."
IK20 has a smaller tip of 0.4mm and IX has a 0.6mm tip, IMO doesn't really make a difference on stock engines.
IX iridium is designed for more performance purposes whereas Laser iridium is designed to match OEM specs.
As for which brand to get, it's up to you and how much you want to spend. Basically they're the same and Toyota recommends both brands for OE replacement.
'00 Camry 5sfe DIY&Custom mods car : Cardomain
-Dual Bi-Xenon HID retrofit w/ custom halos - Custom LED tail light build - Custom black and clear corner lights
-Custom interchangeable Short Ram/Cold Air Intake -Whiteline RSB - Custom Rear Strut Bar
DxElite is offline
post #7 of 36 Old 09-14-2009, 09:41 PM
イリジウム
Quoted: 259 Post(s)
Some people, like myself, prefer NGK plugs. Others prefer Denso. That's all.
Based on the Denso FAQ, I would say longevity from longest to shortest are:
1. NGK Laser Iridium, with platinum ground pad ~120K miles
2. NGK Iridium-IX, basically #1 without the platinum ground pad ? miles
3. Denso iridium with thin center electrode and no Pt ground pad ~30K miles
Therefore I'd recommend NGK Laser Iridum.
Im so confused
JohnGD is offline
post #8 of 36 Old 09-14-2009, 09:56 PM
96 3MZ M/T
chronoti's Avatar
Quoted: 0 Post(s)
personaly i'm cheap with this.
ngk from the factory
toyota owns a share of denso.
^ and leaving it that way!
chronoti is offline
post #9 of 36 Old 09-14-2009, 09:58 PM
I HAS BOOST!!!
bigbird's Avatar
Quoted: 0 Post(s)
iTrader Score: 28 reviews
to be honest,for stock application, either company is more then good enough. denso is OEMish for yota and they are VERY good. its safe to say that the cheapest of the two copmpanies would be fine. but if ya want better...then which ever has the highest ware rating is the one you should get...alot of what makes thoes plugs good(depending on model) makes a differance on boosted motors.
bigbird is offline
post #10 of 36 Old 09-14-2009, 09:59 PM
Vivir el momento
Quoted: 34 Post(s)
Either or is fine.
PhatRoyale is offline
post #11 of 36 Old 09-15-2009, 12:44 AM
Quoted: 0 Post(s)
I have the Denso Long Life Iridium SK20R11 and NGK OEM Laser Iridium IFR6T11 side by side.
Both are suppose to be long life plug with iridium tip and platinum pad.
I think the NGK is nicer than the Denso because on the ground electrode, NGK is much thicker than Denso if this does matter. I will choose NGK over Denso in this application.
Kitto is offline
post #12 of 36 Old 09-15-2009, 01:52 AM
touringcamry's Avatar
Quoted: 3 Post(s)
NGK and Denso are both fine plugs. Toyota uses both brands in manufacturing. On the V6, sometimes you see one bank with Denso and the other with NGK.
IMO, get which ever one costs less because you won't notice any difference between the NGK and Denso. If the price difference is negligible or you're willing to pay it, get whichever one you think is better.
2007 Camry 2.4L 5M
touringcamry is offline
post #13 of 36 Old 09-15-2009, 03:02 AM
Died around age 230, XXX
96ToyoCam164K's Avatar
Quoted: 0 Post(s)
I just put NGK plug wires on mine...anything was better than the swollen up one that didnt stay inside the cylinder
According to Napa, on the NGK box it says 'direct OEM replacement'. Im buying fro,m Napa from now on...
96ToyoCam164K is offline
post #14 of 36 Old 09-15-2009, 08:13 AM
Camry: 94-I4 and 94-V6
Quoted: 8 Post(s)
Hi,
I will go with NGK.
I'd like to ask some related questions if you don't mind:
Do I need to read my manual or do I just go to NAPA and they will give me the RIGHT plugs for my 1994-I4-Camry ?
Can they mixed up between V6 and I4 plugs ?
I've heard 2-ground plugs are REQUIRED on larger toyota engines, what about my 94-I4 ?
THANK YOU FOR YOUR INSIGHT.
sintox is offline
post #15 of 36 Old 09-15-2009, 10:08 AM
Darkside Cut Me!!!
Quoted: 3 Post(s)
The 6 and 4 cylinder engines should be using the same plug, just let the parts counter know your car's information.
Be sure to check gap of the plug.
Most plug manufacturers sell plugs in pre-gapped version, such as NGK with a part number then the last digits, separated with '-' specify the gap. Otherwise they are not pre-gapped.
Iridium plugs usually advise NOT to change the gap.
2 grounded plugs not required for your car.
2004 RX330 Sport
2004 Matrix XR
1998 CamCE I4 Super Commuter!
1997 CamLE I4
Gone:
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
Hajoca is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
« Back
