cigarette lighter not working - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 23 Old 11-24-2009, 04:13 PM Thread Starter
Popping flames
Plbiohazard's Avatar
Quoted: 0 Post(s)
(Thread Starter)
My Cigarette lighter in my glove compartment doesnt work and never did work for some reason any ideas how i can fix it?
Plbiohazard is offline
post #2 of 23 Old 11-24-2009, 06:34 PM
Quoted: 0 Post(s)
Possibly a blown fuse.
ricamryman is offline
post #3 of 23 Old 11-24-2009, 07:21 PM
How hard can it be?
uibalnme's Avatar
Quoted: 11 Post(s)
There's no lighter in the glove box. At least not in my Camry. Any pics of it.
"True terror is to wake up one morning and discover that your high school class is running the country." - Kurt Vonnegut
Cardomain: 1)96 Toyota Camry LE 2)1965 Ford Mustang 3)1998 Toyota Sienna XLE
uibalnme is offline
post #4 of 23 Old 11-24-2009, 08:51 PM Thread Starter
Popping flames
Quoted: 0 Post(s)
(Thread Starter)
Idk I have one I tried using it before but it didn't work so I didn't bother but now it would really come in handy cuz I don't wanna buy the adapter for 2 cigerette lighters out of one the work like crap and look like it to its not a blown fuse that I know of ill try to post up pictures by tomorrow.
post #5 of 23 Old 11-24-2009, 10:55 PM
the_professional's Avatar
Quoted: 6 Post(s)
Your Right.
Only cigarette lighter on the Gen 3's are right next to the radio.
Your cigarette lighter in the glove box was a later, aftermarket addition to your car by the previous owner. Maybe it was more convenient there to charge electronics.
It depends on what the power source is for the cigarette lighter, depending on where it was spliced from. Its obviously not spliced from the other cigarette lighter, as the other works. Maybe it was a crappy splice or low gauge wire. I think you may have to take your glove & dash apart to get at that one.
1992 Toyota Camry LE 2.2L 5S-FE - 73K
FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS 3.2L C32A - 87K
MUCH MORE MODS...
the_professional is offline
post #6 of 23 Old 11-25-2009, 07:58 AM
Quoted: 0 Post(s)
i have the same problem. the cigarette lighter dont work now. it shouldn't be the fuse, cause radio is still working. ligther / radio are using the same fuse. anyone have a video show us how to take out the cigarette lighter and replace it?
aoe_mp is offline
post #7 of 23 Old 11-25-2009, 11:23 AM
Quoted: 0 Post(s)
On my Gen 4.5 (2000 Camry) the radio had two fuses. One under the hood, and one behind the coin holder.
I believe the cigarette lighter, and the power port have seperate fuses. This should be in the owners manual.
I've taken the Cigarette lighter out before to replace the bulb in the lighter stay. It wasn't too bad. I know how to do that in a GEN 4, but never did it in the GEN 3.
skuttduck is offline
post #8 of 23 Old 11-25-2009, 10:02 PM
Quoted: 0 Post(s)
how do you take the lighter out?
aoe_mp is offline
post #9 of 23 Old 11-25-2009, 10:12 PM
asphalt victory's Avatar
Quoted: 6 Post(s)
you take the black plastic cover plate off the pull and tug and twist () gently untill it comes out there is a yellowish plastic cover that protects the positive and negative sometimes theyr just loose and you can pry them on with plyers use a cell phone charger as a test light
MAY AN EMPTY PARTS BOX BE MY WINNING TROPHY
asphalt victory is offline
post #10 of 23 Old 01-26-2010, 12:55 PM
tekno9000's Avatar
Quoted: 0 Post(s)
My radio works too. However which is the fuse that would cause the lighter to not work?
Thanks
Thanks,
Tekno 9000
1995 Camry LE 5SFE 4 Cyl.
tekno9000 is offline
post #11 of 23 Old 01-26-2010, 01:57 PM
Ninja wrench anywhere
hill8570's Avatar
Quoted: 3 Post(s)
In the '94 5S-FE rigs, there's just the CIG/RADIO fuse. It's in the fuse box behind the coin box (to the left of the steering wheel). To remove the coin box, open it, then press the tabs inside to finish removing it. The fuse box has all the fuses labeled.
However, if the radio is working (assuming it's OEM) doesn't seem likely that it's a fuse problem -- it's either going to be a problem with the socket itself (easy to test with a multimeter or a cell phone charger) or with the lighter itself. If the radio is aftermarket, 'tho, definitely check the fuse -- I've seen some pretty bizarre kludges from bozos installing aftermarket radios.
hill8570 is offline
post #12 of 23 Old 01-26-2010, 01:57 PM
Quoted: 0 Post(s)
It's a warning to "STOP SMOKING"
ehoff is offline
post #13 of 23 Old 01-26-2010, 06:59 PM
Justin
JJ9284's Avatar
Quoted: 0 Post(s)
Originally Posted by the_professional View Post
Your Right.
How bout the 3.5's??? That would help me out so much!
1995 Camry
JJ9284 is offline
post #14 of 23 Old 01-26-2010, 07:51 PM
rusty9's Avatar
Quoted: 0 Post(s)
i think you are all missing the most obvious. these things do burn out... go buy a new one at the parts store for 3 bucks.
rusty9 is offline
post #15 of 23 Old 01-26-2010, 10:16 PM
Quoted: 6 Post(s)
I'm not exactly sure what your asking.
If your asking if a glovebox cigarette lighter was on the 3.5s, then, no they were not.
I hope thats what you were asking about.
MUCH MORE MODS...
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
