brake light comes on/off in the cold - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 12 Old 12-12-2009, 10:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just recently when temperatures have gone below freezing, my brake light randomly comes on and off in my 2000 camry ce. The light will come on randomly and stay on for a random amount of time (1-8 mins) until it goes off randomly. It usually happens during the first 20 minutes of driving in freezing temps, and does not happen during warm weather.
The emergency brake is working and has proper breaking force. There is still 5-8 clicks from the down position to up position. I'm not sure why the light is coming on and off, but my car is a m/t and I do need the e-brake to work always.
Anybody else have this problem before?
vulcanraven is offline
post #2 of 12 Old 12-12-2009, 10:42 PM
Ninja wrench anywhere
hill8570's Avatar
Quoted: 3 Post(s)
Have you checked the brake fluid level in the fluid reservoir (engine compartment, usually up near the firewall on the driver's side of the car)?
When is the last time you had the brakes flushed?
hill8570 is offline
post #3 of 12 Old 12-13-2009, 12:56 AM
イリジウム
Quoted: 247 Post(s)
Also, have you inspected the brake pads lately? Usually the fluid level corresponds to the pad thickness. If all work done properly you're likely low on friction material too.
Brake fluid should be changed every two years. I'd use Castrol GT LMA or Valvoline Synthetic. Both are Low Moisture Activity fluids.
JohnGD is offline
post #4 of 12 Old 12-13-2009, 10:12 AM
Quoted: 0 Post(s)
The parking brake indicator light? You must have a bad switch on the ebrake, I believe you need to remove the center console to get to the switch.
Kenny_McCormic is offline
post #5 of 12 Old 12-13-2009, 10:50 AM
the_professional's Avatar
Quoted: 6 Post(s)
With the symptoms your describing it sounds like your low on brake fluid. & Like others said, you should check out your pads too, as more fluid is required as your pads wear down.
Best of Luck.
1992 Toyota Camry LE 2.2L 5S-FE - 73K
FOG LAMPS|PIONEER HU&AUDIO|KEYLESS ENTRY
1995 Acura Legend LS 3.2L C32A - 87K
MUCH MORE MODS...
the_professional is offline
post #6 of 12 Old 12-13-2009, 11:06 AM
Chris Crash's Avatar
Quoted: 30 Post(s)
iTrader Score: 13 reviews
The BRAKE light comes on not only for e-brake issues, but for fluid issues as well. Check them both.
My car was low on brake fluid once so only when I would accelerate, brake or hit a turn hard would the light come on. Took me forever to figure out which light was actually blinking!
Chris Crash is offline
post #7 of 12 Old 12-13-2009, 01:01 PM
Quoted: 0 Post(s)
Contaminated Brake Fluid
My Daughter's 2000 Camry had the same issue with the brake light coming on intermittently.
When I checked the fluid, it was up to the full level. The brake pads were done recently.
I took a turkey baster and removed all the fluid in the master cylinder and upon inspection noticed the fluid was kind of thick and gooey. Added fresh fluid to the master cylinder and gave the master cylinder a couple of whacks to "free up" the switch inside. That was 3 weeks ago and all is well.
I will be doing a complete brake fluid exchange in the warmer months.
hzt30 is offline
post #8 of 12 Old 12-18-2009, 01:14 PM
Rides a 1990 Camry
Quoted: 0 Post(s)
Folks, my 1990 Camry has recently started with this same behavior. Am I correct in assuming the low fluid issue also applies to my generation Camry?
As to what to do about it, if it's a matter of topping-off fluid, I'd imagine I can handle that. As for flushing the brakes, how involved does that get? If it's easy for a novice like me, all is well... otherwise I've got a dilemma in that we're getting ready to sell this car soon (you guys are certainly welcome to it...) and I'm hoping not to sink piles of money into a car I may not have much longer. It's been a GREAT car but mom just offered us her Subaru, with a third the miles on it, if we get rid of our Camry first. (sigh.)
Any suggestions as to the right course of action for my case? Much appreciated!
milkyspit is offline
post #9 of 12 Old 12-18-2009, 06:15 PM
hill8570's Avatar
Quoted: 3 Post(s)
Yup. In fact, "brake light intermittently flashing when brake fluid is sort of low" and "brake light on continuously when brake fluid is really low" applies to pretty much any car I've owned, and that includes some US rigs from the 60's.
As long as the underside of the car isn't particularly rusty, bleeding brakes isn't hard -- I used to help my dad do it when I was about 12. Actually probably younger than that the first time, but then I was just the designated brake pusher.
Helps to have a jack and some jackstands, 'tho -- it's more than a little cramped under there without having it off the ground another foot.
hill8570 is offline
post #10 of 12 Old 12-18-2009, 07:14 PM
イリジウム
Quoted: 247 Post(s)
Brake fluid absorbs moisture directly from the air. They should be changed no longer than every two years. I do it every year. Cheap enough with a quart of Castrol GT LMA or Valvoline Synthetic (both are Low Moisture Activity fluids).
Go to advanceautoparts.com
--> Click on "Advance Know-How" Tab on upper right of page
--> Click on "Know-How Articles"
--> Click on "DIY Maintenance"
--> Click on "Brake Bleeding".
JohnGD is offline
post #11 of 12 Old 12-18-2009, 07:18 PM
イリジウム
Quoted: 247 Post(s)
How long has that fluid been in there? That's a sign the fluid has deteriorated. Honda's brake fluid is especially bad. Some say it's made by CCI.
I use only Castrol GT LMA or Valvoline Synthetic.
JohnGD is offline
post #12 of 12 Old 12-18-2009, 10:53 PM
Quoted: 0 Post(s)
3rd Generation
my 96 Camry DX does the same thing, but only when it's cold out as well. the brake light eventually goes off when the engine reaches the highest temperature. i'm due for a brake fluid service as well. it's way too cold to do it myself though.
1996 Toyota Camry LE [130K]
Camry LE 94 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
