93 camry v6 code 52 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 6 Old 02-13-2010, 10:02 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation 93 camry v6 code 52
Hello again, The Toyota dealership tells me my CEL is a code 52. Would that indicate that 1 of the 2 knock sensors/wiring are still OK?
I am considering stripping the insulation from both knock sensor wires and connecting the wires together, to see if that turns the CEL off.
Just bought this car 'as-is' a little over two weeks ago. Great car, just needs a little TLC.
Several other things still need repair, and I don't want to pull the intake yet.
Just want to know if connecting both sensor wires together may work. Thank you
brian long is offline
post #2 of 6 Old 02-13-2010, 11:26 PM
Ninja wrench anywhere
hill8570's Avatar
Quoted: 3 Post(s)
Yup, DTC 52 means knock sensor #2 (left bank sensor) is hosed.
I don't think you can use the output of #1 to go to both inputs on the ECU -- the knock sensor has very low output, and it probably would go too noisy. Not certain, 'tho.
Might want to try relocating sensor #2 to someplace more convenient. I've seen a post on that for the 1MZ (1MZFE - Tips on Changing Valve Cover Gaskets and Relocating Knock Sensors ) same principle might work for the 3VZ .
hill8570 is offline
post #3 of 6 Old 02-14-2010, 10:21 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
I'm going to give it a try. Since I plan on replacing the wire and both sensors if I pulll the intake, i've got nothing to lose?
I have heard several ways to clear the codes, please tell me what really works.
I would prefer to remove the EFI fuse. How many minutes should it be removed?
Thank you
post #4 of 6 Old 02-14-2010, 10:33 AM
Senior TN Member
Nervous's Avatar
Quoted: 1 Post(s)
Just remove the EFI fuse for several seconds - will be enough.
Nervous is offline
post #5 of 6 Old 02-14-2010, 11:10 AM
Quoted: 0 Post(s)
I combined the two wires and the light went away. Do you know how many miles per gallon you're getting right now? Mine has been getting 13 mpg for the longest time.
03 Max modded //sold
07 Camry XLE i4, all stock.
LUVLEXUS101 is offline
post #6 of 6 Old 02-14-2010, 05:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
not sure of the MPG. probably not good. lots of idling while I work on it in a poorly heated garage.
long story......
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
