Which antifreeze? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 04-05-2010, 08:45 AM Thread Starter
Quoted: 3 Post(s)
(Thread Starter)
Which antifreeze?
Have an unopened gallon of the green prestone concentrate antifreeze. Can I use this in my 97 Camry for a coolant flush or do I have to get the official Toyota antifreeze at the dealer $$$??
Thanks
Dave
dave52 is offline
post #2 of 5 Old 04-05-2010, 08:53 AM
Default User Title
Quoted: 40 Post(s)
Toyota red coolant mixed with conventional green
Don't forget to search the forum before posting! Thanks.
05 Camry LE I4 90k
95 Camry LE I4 228k
97 Miata NA8 123k
16 Camry LE I4 3k
03 Camry LE I4 90k
I guess I hate even generation Camrys?
bdy0003 is offline
post #3 of 5 Old 04-05-2010, 09:56 AM
Quoted: 0 Post(s)
I would look for Peak Global lifetime at a store like Napa or Zerex Asian formula if you don't want to go to the dealer. Zerex only comes in a 50/50 mix though.
Fortified Souls is offline
post #4 of 5 Old 04-05-2010, 05:35 PM
'95 Camry 5S-FE
Quoted: 1 Post(s)
If you currently have green in the car, yes it will be fine.
If you currently have red in the car, you would have to COMPLETELY flush the system out first. If you mix red and green antifreeze it will create deposits and possibly clog the system.
There are really only 2 rules to follow:
1) Don't mix red and green antifreeze
2) If using concentrate, only mix with DISTILLED water. Tap water (and sometimes filtered water) can leave deposits in the system.
Follow those 2 rules and you'll be fine.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline
post #5 of 5 Old 04-05-2010, 11:08 PM
イリジウム
Quoted: 252 Post(s)
Prestone has not sold the traditional green silicated antifreeze for a long time. It's the "All makes" Dexcool clone now. I'm not sure about the shelf life of the inhibitor. But > 5 years I probably won't use it. You can call Prestone and ask for a more accurate answer. Can't remember from reading posts.
The Toyota super long life coolant, Zerex Asian Vehicles coolant, Peak Global are all organic acid type coolants that use phosphates in place of the problematic plasticizer 2EHA acid used in Dexcool. If you have the 5SFE bi-metal engine (aluminum head and iron block), then I'd stick to the Toyota Red every 2 years/30K miles. Besides, you'll have the hang loose plastic vacuum valve on the radiator cap that lets air in. Organic acid type coolants hate that and can turn to gel when air is in the system.
The silicated old green is excellent in bi-metal engines and so is the G-05 low silicate coolant. However, if there is cheap rubber pump seal in there then silicates will wear them out much sooner than pumps with carbide seals. Most Asian pumps come with less expensive rubber seals, so they require no silicates in the coolant.
Thanks
Dave
JohnGD is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
