Replaced battery - radio not working - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 27 Old 11-10-2010, 01:20 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I hope you guys can help me out!
2000 Toyota Camry LE V6
Wouldn't start after work Monday, had it jumped off.
Went about 1 mile and the electronics started flickering and the car shut off, had it jumped off.
Went about 3 miles and same thing.
Took the battery out and replaced it.
:::that alarm scared the crap out of me:::
Now the radio doesn't work. No lights showing on the display.
The alarm does work.
What should I do?
Thanks
cr107423 is offline
post #2 of 27 Old 11-10-2010, 01:21 PM
Chris Crash's Avatar
Quoted: 30 Post(s)
iTrader Score: 13 reviews
Check your fuses.
2016 Toyota Corolla S Plus 6-speed
2015 Dodge Ram 1500
1997 Toyota Camry LE 5-speed
1994 Toyota Camry J-Vin
1997 Toyota Camry CE 5-speed
Chris Crash is offline
The Following User Says Thank You to Chris Crash For This Useful Post:
cr107423 (11-11-2010)
post #3 of 27 Old 11-10-2010, 01:26 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 678 Post(s)
Possibly the anti theft security code needs to be entered? I've never activated the security code on mine so I don't know how it's done.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is online now
post #4 of 27 Old 11-10-2010, 01:27 PM
92 Camry 5S-FE
LittleWhiteBubble's Avatar
Quoted: 0 Post(s)
^ agree with the fuse being the culprit on the dash lights. But if the car died while running, and more than once, you probably have a bad alternator. Most cars you can take the battery out of while its running and drive away.
LittleWhiteBubble is offline
The Following User Says Thank You to LittleWhiteBubble For This Useful Post:
post #5 of 27 Old 11-10-2010, 01:28 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
replaced to radio fuse, still nothing.
cr107423 is offline
post #6 of 27 Old 11-10-2010, 01:28 PM
92 Camry 5S-FE
Quoted: 0 Post(s)
A bad voltage regulator or failing alternator could have spiked the electrical and blown the fuse.
Was the radio fuse blown?
post #7 of 27 Old 11-10-2010, 01:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
had the alternator checked yesterday, they said it's fine
cr107423 is offline
post #8 of 27 Old 11-10-2010, 01:29 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
the old fuse looked ok to me. I'm no expert but didn't look like anything was messed up on the inside of it
cr107423 is offline
post #9 of 27 Old 11-10-2010, 01:33 PM
92 Camry 5S-FE
Quoted: 0 Post(s)
If the element inside isn't busted then the fuse was fine. Alternators can test fine and still be bad depending on what test they did. It should be tested under load. Is it a stock radio or aftermarket? Aftermarket radios have fuses on the back of them also, not sure about the stock units but I assume they would too. As for the dash lights, that may be a separate fuse from the radio. Did you check all of them?
post #10 of 27 Old 11-10-2010, 01:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Resetting the alarm system:
http://www.ehow.com/how_6526136_rese...ry-change.html
Do you guys think this would do the trick? If the alarm didn't work I would definitely try this. But it's really just the radio.
cr107423 is offline
post #11 of 27 Old 11-10-2010, 01:36 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I did not check all of the fuses. I'll do that later today.
It is a stock radio
cr107423 is offline
post #12 of 27 Old 11-10-2010, 01:38 PM
92 Camry 5S-FE
Quoted: 0 Post(s)
It may still have a fuse on the back of the head unit. I would check all the related fuses before worrying about any relearn procedure. The reset wouldn't keep your dash lights from working.
post #13 of 27 Old 11-10-2010, 01:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
LittleWhiteBubble - when I wrote that the lights were not working I am referring to just the display lights on the radio. All the gauge lights are working fine. You may already understand that, but just wanted to be clear.
So you suggest taking the radio out and checking the back of the unit for a fuse there? I'll try that later today and let you know.
cr107423 is offline
post #14 of 27 Old 11-10-2010, 01:52 PM
Quoted: 30 Post(s)
I don't think there's a fuse on the back, but you probably need to take the radio out to probe the wires anyway.
2015 Dodge Ram 1500
post #15 of 27 Old 11-10-2010, 01:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I had an idea that it was part of an anti-theft feature and maybe there was a code of some sort to get the radio working again. Does this sound familiar to anyone?
Tried to call the dealership but they just transfer me to someone with voice mail and left a message.
cr107423 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
