1992 camry fuel filter change need help - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 4 Old 12-05-2010, 09:24 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
alright so i need some help changing my fuel filter, i tried to do it today and when i took of the bolt on the top it started pouring out fuel , it it wont stop so i dont know what to do , i change change it if it keeps pouring , am i doing it right? is there any diy's? if anyone can help me please reply. and how often does it fuel pump have to be replaced.
armaniran is offline
post #2 of 4 Old 12-05-2010, 09:44 PM
Senior TN Member
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Quoted: 4 Post(s)
Fuel pump and filter don't need replacing unless you have identified problems with them. What engine and mileage? Opening the gas cap may relieve some pressure. Pulling the EFI fuse and cranking a little may help also. It shouldn't leak alot of fuel.
http://hubpages.com/hub/90-01-Toyota...-Body-Cleaning
It worked fine until I fixed it!
csaxon is offline
post #3 of 4 Old 12-05-2010, 11:34 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
its the v6 le 3vzfe i belive
thanks guys
post #4 of 4 Old 12-06-2010, 08:15 AM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
iTrader Score: 8 reviews
If you remove the banjo bolt (Top bolt on filter) and gas keeps pouring out ... Simply open the fuel door and remove the gas cap. Easy as 1 2 3
Will be the same for removing the bottom bolt. You will get a little gas, but it wont keep flowing once the gas cap is removed
Perkins is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
