93 camry rear shakng - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 18 Old 12-16-2010, 12:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a 93 camry le 237XXX AUTO ... recently my camry have been making some thumbbing cluncking shaking from the middle rear when i approrach 45 mph and above. the steering wheel does not shake. I dont know where to start please any advice would be helpful.
logic612 is offline
post #2 of 18 Old 12-16-2010, 12:55 PM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
iTrader Score: 8 reviews
Make sure the belts on the tires are not broken, Make sure the rims are not bent.
Physically feel the top of the tire for bumps or abnormal wear
Jack the tires in the rear off the ground and move the tires around feeling for any looseness.
Grab the tire at 12 o clock and 6 o clock and push and pull.
Grab the tire at 3 o clock and 9 o click and push and pull.
Each time seeing if there is play in any direction. If there is play, have a helper climb under while your moving the tire and see what is moving
Also, While the tire is off the ground.. grab a pry bar or something long and hard and place it under the tire and lift the pry bar up, moving the tire up a little bit checking for looseness or sounds.
Make sure to use Jack Stands in case the Jack falls over
Broken belts are a very common reason why you get bad vibrations. If you do not find anything out of the ordinary, take it to a tire shop and have them inspect them
Perkins is offline
post #3 of 18 Old 12-16-2010, 02:24 PM
tacosteelersman's Avatar
Quoted: 0 Post(s)
+1 on tire issues.
My parents 96 avalon was thumping and vibrating, their Douglas tires had several flaws. New rear tires and the car was rolling perfect again. Take good advise everything Mr Perkins posted above is on the money 100%...
95.5 Tacoma 2.7 300,000
91 Corolla 1.6 180,000
96 Avalon 3.0 190,000
95 Ford Aspire 1.3 125,000
tacosteelersman is offline
post #4 of 18 Old 12-16-2010, 06:25 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
so it looks to me the driver side lateral link( joint area) is thumping with the other link. the bushings are worn down. could i get instruciton on how to replace the lateral link.
logic612 is offline
post #5 of 18 Old 12-16-2010, 09:32 PM
Quoted: 0 Post(s)
I am confused about the words lateral link. Are you talking about the swaybar end link? The factory endlinks can be a pain to remove.. First things first GET A MANUAL factory repair manual is best but Haynes makes an ok manual. If I were you, I would click the white box labled (gen 3 owners click here)in Mr Perkins signature and look around at some of that info..
post #6 of 18 Old 12-17-2010, 10:47 AM
Quoted: 0 Post(s)
He is not talking about the endlink. There is an adjustable link going to the rear wheels from the vehicle with bushings on each end. I had a buddy help me replace one on the wagon. It's pretty straight forward...unbolt the old one, bolt the new one in. I would go get an alignment afterwards though.
curry.style is offline
post #7 of 18 Old 12-17-2010, 10:53 AM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
If you measure the amount of thread sticking out from where the nuts / adjustment nut assembly you can just make sure the amount of threads are exactly the same and you will not have to re-align it
Perkins is offline
post #8 of 18 Old 12-17-2010, 11:01 AM
Quoted: 0 Post(s)
Yeah, that's what we did with mine, but I figured that's not necessarily the easiest thing to do for everyone.
331,000 miles and the wife's 1995 Camry LE finally bit the dust...but we can rebuild it, we have the technology...
1993 Camry LE wagon, 4 cyl, 5 spd swapped...more to come...
post #9 of 18 Old 12-17-2010, 11:08 AM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
I actually just replaced these on the 92 XLE Yesterday. 21MM Wrench for the adjustment nut & locking nut, 19MM for the nut that attaches to the knuckle assembly.
If you have a LSPV then the nut is a 12MM.
It also makes it easier to have the tire off. Just please dont forget to use jack stands. Air tools will make it easier to take the 19mm nut off, but you can wrench it out too with a cheater bar if needed.
Perkins is offline
The Following User Says Thank You to Perkins For This Useful Post:
curry.style (12-17-2010)
post #10 of 18 Old 12-17-2010, 11:32 AM
Quoted: 85 Post(s)
Toyota refers to that part as "Rear Lateral Control Rod Number 2". I had to replace one a couple of years ago on my 94 Camry.
Mike
Mike Gerber is offline
post #11 of 18 Old 12-17-2010, 12:22 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks seem straight forward to repair.. ill report back with a update
logic612 is offline
post #12 of 18 Old 12-18-2010, 02:14 AM
pmx007PL's Avatar
Quoted: 1 Post(s)
3rd Generation Similar problem. Bushings OK?
I have similar problem (rear suspension "hit" noise) and my rear wheels are little bit moving when I shake them by the hands (car jack'd up). I found that rear track control arms bushings are worn. I bought complete set of bushings (+ sway bar rubbers)...
And my question: is those rubbers/bushings are OK or not for 1994 5S-FE Camry? Please look at the pics and tell what you think...
Now I don't have opportunity, to replace them (or only look under the car, to compare new with old ones), cause it's winter with heavy snowing here (+ Christmas time coming).
Bushing numbers (from next pic) are: 5, 7, 8, 9, 10, 11, 12.
So, it all looks fine (will fit) or not?
Last edited by pmx007PL; 12-18-2010 at 02:18 AM. Reason: Please answer, what do You think...
pmx007PL is offline
post #13 of 18 Old 12-18-2010, 07:26 AM
Quoted: 0 Post(s)
Did you buy used bushings? Probally not your best bet..
post #14 of 18 Old 12-18-2010, 08:40 AM
esvipron's Avatar
Quoted: 0 Post(s)
4th Generation
Probable is the Tie Rod behind the tire, and it is not that hard to replace.
esvipron is offline
post #15 of 18 Old 12-18-2010, 09:47 AM
Quoted: 0 Post(s)
I bought the whole link from Toyota. I was told you could not get just the bushings. LMK how those work out. I have a feeling I'll be doing this at least three more times (the side I didn't do on the wagon, and both on the other car.)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
