How long will Iridium Plugs Last? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 28 Old 03-02-2011, 05:57 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation How long will Iridium Plugs Last?
I bought some NGK Iridium Plugs for my 93 LE, 3VZFE V6 Camry, how long will these plugs last? Can I go 100K miles?......
ricamryman is offline
post #2 of 28 Old 03-02-2011, 06:01 PM
Freakin Scooters
LynchburgCSI's Avatar
Quoted: 0 Post(s)
iTrader Score: 16 reviews
Which kind of Iridium? IIRC, the 3VZ uses a distributor waste spark system and benefits from the use of a certain type of spark plug.
Honda Scoots Galore
LynchburgCSI is offline
post #3 of 28 Old 03-02-2011, 06:09 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
NGK Iridium Plug # BCPR6EIX-11, according to NGK's site this is the proper plug for the 1993 3VZFE....
post #4 of 28 Old 03-02-2011, 06:31 PM
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Quoted: 4 Post(s)
iTrader Score: 13 reviews
Factory Iridium Plugs are good for 120K
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline
post #5 of 28 Old 03-02-2011, 06:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
Sounds like after I install these, they could quite possibly be the last set of plugs I will ever need?......Since I am at 134K miles......Nice!....
post #6 of 28 Old 03-02-2011, 06:51 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
NGK Iridium-IX in waste spark system?? I wouldn't trust them after 30k miles, just IMHO ...
Denso Double Platinum or NGK Laser Platinum 60-90k miles should be OK...
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
post #7 of 28 Old 03-02-2011, 06:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
I highly doubt NGK would make them & specify them for my particular application, if they would not last a while?........
post #8 of 28 Old 03-02-2011, 07:02 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
well, they are also SPECIFIED for gen4 camry, solaras and so on, only difference vs OEM factory design (double ground electrode) is the Iridium-IX have a single ground, so they last up to roughly half the time double ground OEM plugs in a waste spark system ...
http://www.ngksparkplugs.com/part_fi...uv/results.asp
fenixus is offline
post #9 of 28 Old 03-02-2011, 07:11 PM
Freakin Scooters
Quoted: 0 Post(s)
Looks like those are the Iridium IX plugs. They'll work perfectly fine, but i'm pretty sure you're supposed to stick with Laser Platinums. edit: Yep, posts above confirm that.
Standard BCPR6ES-11
6779
V-Power BCPR6E-11
5632
G-Power BCPR6EGP
7088
Laser Platinum BCPR6EP-11 * #
3350
Iridium IX BCPR6EIX-11
4919
* “Laser Series” Platinum center electrode, and Platinum pad ground electrode
# Original Equipment Manufacturer, and/or Original Equipment Service Part
^ “Laser Series” Iridium center electrode, and Platinum pad ground electrode
Honda Scoots Galore
post #10 of 28 Old 03-02-2011, 07:12 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
I guess the only way I will find out is when I install them and drive for 30K miles, then report back here on how the car is running!.....
post #11 of 28 Old 03-02-2011, 07:13 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
by all means, use them if you have them already, they are VERY decent plugs
just don't expect them to last as long as OEM would.
fenixus is offline
post #12 of 28 Old 03-02-2011, 07:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation
How long do the OEM plugs last? I had the Toyota Dealer replace my current ones around 30K miles ago?.......
post #13 of 28 Old 03-02-2011, 07:19 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
they should be good for 60k or up to 90k miles with no problems. I would keep the OEM ones in there for at least another 30k miles.
just check what shape they are in, color and so on.
fenixus is offline
post #14 of 28 Old 03-02-2011, 07:24 PM
Senior TN Member
Quoted: 226 Post(s)
There is a sticker that even says not to use single electrode plugs on the 1mz, pretty sure its the same for the 3vz too.
According to what Lynch posted you need, NGK Laser Platinum BCPR6EP-11 or Toyota Denso Plugs. Doing the rear bank plugs is not much fun as it is. I wouldn't want to replace them again in another 30k miles.
pmesfun is offline
post #15 of 28 Old 03-02-2011, 07:26 PM
Senior TN Member
Quoted: 226 Post(s)
I assume they used Toyota Denso Double Platinum, so it should last for another 90k miles if I'm not mistaken. Service Interval says to replace Double Platinum plugs every 120k.
pmesfun is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
