FYI - 2000 Camry torque Spec - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 06-28-2011, 12:06 PM Thread Starter
double dose camry
Quoted: 5 Post(s)
(Thread Starter)
TORQUE SPECIFICATION
Part tightened N·m kgf·cm ft·lbf
FRONT:
Hub nut 103 1,050 76
Tie rod end lock nut 74 750 54
Steering knuckle x Shock absorber 211 2,150 156
Steering knuckle x Brake caliper 107 1,090 79
Steering knuckle x Tie rod end 49 500 36
Axle hub x Drive shaft 294 3,000 217
Lower ball joint x Lower suspension arm 127 1,300 94
Lower ball joint x Steering knuckle 123 1,250 90
Steering knuckle x Disc brake dust cover 8.3 85 74 in.·lbf
Drive shaft center bearing lock bolt 32 330 24
Suspension support x Body 80 820 59
Suspension support x Piston rod 49 500 36
ABS speed sensor set bolt 8.0 82 71 in.·lbf
Flexible hose and ABS speed sensor wire harness x Shock absorber 29 300 22
Lower suspension arm set bolt 206 2,100 152
Stabilizer bar bracket x Suspension member 19 195 14
Stabilizer bar link set bolt 39 400 29
REAR:
No.2 lower suspension arm lock nut 56 570 41
Brake caliper x Rear axle carrier 47 475 34
Axle hub bearing set bolt 80 820 59
Shock absorber x Rear axle carrier New nut
Reused nut (apply engine oil the threads)
Flexible hose x Shock absorber 29 300 22
ABS speed sensor wire harness x Shock absorber 5.5 56 49 in.·lbf
Rear side seatback set bolt 18 185 13
Suspension support x Body 39 400 29
Exhaust center pipe set nut 56 570 41
Parking brake cable set bolt 5.4 55 48 in.·lbf
Lower suspension arm x Suspension member 181 1,850 134
Lower suspension arm x Rear axle carrier 181 1,850 134
Strut rod x Body 113 1,150 83
Strut rod x Rear axle carrier 113 1,150 83
Suspension member x Body 51 520 38
Suspension member lower stopper sub–assembly x Body 38 390 28
Stabiliser bar link set nut 39 400 29
Master cylinder x Piston stopper bolt 10 100 7
Master cylinder x Reservoir 1.7 18 16 in.·lbf
Master cylinder x Brake booster 13 130 9
Brake line union nut 10 mm nut 15 155 11
12 mm nut 20 200 14
Brake booster clevis lock nut 25 260 19
Brake booster x Pedal bracket 13 130 9
Brake pedal x Pedal bracket 39 400 29
Pedal bracket x Instrument panel reinforcement 13 130 9
Front brake caliper installation bolt 34 350 25
Bleeder plug 8.3 85 74 in.·lbf
Front brake torque plate x Steering knuckle 107 1,090 79
Front brake caliper x Flexible hose 29 300 21
Flexible hose x Shock absorber bracket 29 300 21
Rear drum brake wheel cylinder x Backing plate 10 100 7
Parking brake cable bracket x Backing plate 7.8 80 69 in.·lbf
Rear brake caliper installation bolt 20 200 14
Rear disc brake cariper main pin installation bolt 26 270 20
Rear brake caliper x Flexible hose 29 300 21
Rear brake torque plate x Rear axle carrier 47 475 34
Proportioning valve installation bolt 8.8 90 78 in.·lbf
ABS actuator x Actuator bracket DENSO type 5.4 55 48 in.·lbf
ABS actuator x Actuator bracket BOSCH type 9.0 92 80 in.·lbf
ABS actuator x ECU BOSCH type 2.6 27 23 in.·lbf
ABS & TRAC actuator x Actuator bracket 5.4 55 48 in.·lbf
ABS (& TRAC) actuator bracket x Body 19 195 14
Front speed sensor installation bolt 7.8 80 69 in.·lbf
Front speed sensor harness clamp bolt 5.4 55 48 in.·lbf
Rear speed sensor installation bolt 7.8 80 69 in.·lbf
Rear speed sensor harness clamp bolt 5.4 55 48 in.·lbf
STEERING COLUMN
Steering wheel pad set screw (Torx screw) 7.1 72 63 in.·lbf
Steering wheel set nut 35 360 26
Intermediate shaft assembly x Control valve shaft 35 360 26
Steering column assembly x Intermediate shaft assembly 35 360 26
Steering column assembly set nut 25 260 19
Turn signal bracket x Column tube 7 70 61 in.·lbf
Lower column tube attachment x Column tube 19 195 14
PS VANE PUMP
5S–FE and 1MZ–FE Engines:
Pressure feed tube x Control valve housing 5S–FE Engine 32 (25) 326 (250) 24 (18)
Pressure feed tube x Pressure feed tube 1MZ–FE Engine 20 (25) 203 (250) 15 (18)
Clamp plate set nut 5S–FE Engine 10 100 7
Clamp plate set nut 1MZ–FE Engine 7.8 80 69 in.·lbf
PS vane pump set bolt A bolt 29 (43) 293 (440) 21 (32)
PS vane pump set bolt B bolt 43 440 32
Oil pressure switch x Union bolt 21 210 15
Union bolt x Pressure feed tube 52 525 38
Vane pump pulley set nut 43 440 32
Front bracket x Rear bracket 43 440 32
Suction port union set bolt 13 130 9
Pressure port union 83 850 62
Rear housing set bolt 24 240 17
PS GEAR
Pressure feed tube clamp plate set nut 10 100 7
Pressure feed and return tubes x Control valve housing 32 (25) 326 (250) 24 (18)
Stabilizer bar set bolt 19 195 14
PS gear assembly set bolt and nut 181 1,850 134
Turn pressure tube union nut 10 (13) 102 (130) 7 (9)
Rack x Rack end 60 (83) 615 (850) 45 (62)
Rack guide spring cap lock nut 50 (69) 513 (700) 37 (51)
Rack housing cap 59 600 43
Selt–locking nut 25 250 18
Control valve housing set bolt 18 185 13
Steering wheel 35 360 26
Steering wheel pad 7.1 72 63 in.·lbf
Front passenger airbag assembly x Instrument panel reinforcement 20 205 15
Front seat installation bolt 37 375 27
Airbag sensor assembly 20 205 15
Front airbag sensor 20 205 15
Side airbag sensor assembly 20 205 15
I got these data from camry service spec manual. Usefull for those who are looking for torque spec.
John
mail2_jb is offline
The Following 5 Users Say Thank You to mail2_jb For This Useful Post:
Di3S3L (12-31-2013), fenixus (08-25-2011), houra (06-28-2011), Perkins (06-28-2011), pmesfun (06-28-2011)
post #2 of 3 Old 06-28-2011, 01:43 PM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
iTrader Score: 8 reviews
Good Stuff! Stickied!
If you could, can you Edit the text and Bold where the Ft-Lbs are supposed to be.
Such as
I Am assuming that its 103N·m 1050kgf·cm 76ft·lbf
Perkins is offline
The Following 2 Users Say Thank You to Perkins For This Useful Post:
Di3S3L (12-31-2013), fenixus (09-02-2011)
post #3 of 3 Old 08-13-2011, 08:44 AM
2001 Camry XLE 1MZ-FE
Quoted: 41 Post(s)
Such as
Part tightened N/m kg/cm ft/lb
FRONT:
Hub nut 103 N/m, 1,050 kg/cm, 76 ft/lb
Tie rod end lock nut 74 N/m, 750 kg/cm, 54 ft/lb
Steering knuckle x Shock absorber 211 N/m, 2,150 kg/cm, 156 ft/lb
Steering knuckle x Brake caliper 107 N/m, 1,090 kg/cm, 79 ft/lb
Steering knuckle x Tie rod end 49 N/m, 500 kg/cm, 36 ft/lb
Axle hub x Drive shaft 294 N/m, 3,000 kg/cm, 217 ft/lb
Lower ball joint x Lower suspension arm 127 N/m, 1,300 kg/cm, 94 ft/lb
Lower ball joint x Steering knuckle 123 N/m, 1,250 kg/cm, 90 ft/lb
Steering knuckle x Disc brake dust cover 8.3 N/m, 85 kg/cm, 74 in/lb
Drive shaft center bearing lock bolt 32 N/m, 330 kg/cm, 24 ft/lb
Suspension support x Body 80 N/m, 820 kg/cm, 59 ft/lb
Suspension support x Piston rod 49 N/m, 500 kg/cm, 36 ft/lb
ABS speed sensor set bolt 8.0 N/m, 82 kg/cm, 71 in/lb
Flexible hose and ABS speed sensor wire harness x Shock absorber 29 N/m, 300 kg/cm, 22 ft/lb
Lower suspension arm set bolt 206 N/m, 2,100 kg/cm, 152 ft/lb
Stabilizer bar bracket x Suspension member 19 N/m, 195 kg/cm, 14 ft/lb
Stabilizer bar link set bolt 39 N/m, 400 kg/cm, 29 ft/lb
REAR:
No.2 lower suspension arm lock nut 56 N/m, 570 kg/cm, 41 ft/lb
Brake caliper x Rear axle carrier 47 N/m, 475 kg/cm, 34 ft/lb
Axle hub bearing set bolt 80 N/m, 820 kg/cm, 59 ft/lb
Flexible hose x Shock absorber 29 N/m, 300 kg/cm, 22 ft/lb
ABS speed sensor wire harness x Shock absorber 5.5 N/m, 56 kg/cm, 49 in/lb
Rear side seatback set bolt 18 N/m, 185 kg/cm, 13 ft/lb
Suspension support x Body 39 N/m, 400 kg/cm, 29 ft/lb
Exhaust center pipe set nut 56 N/m, 570 kg/cm, 41 ft/lb
Parking brake cable set bolt 5.4 N/m, 55 kg/cm, 48 in/lb
Lower suspension arm x Suspension member 181 N/m, 1,850 kg/cm, 134 ft/lb
Lower suspension arm x Rear axle carrier 181 N/m, 1,850 kg/cm, 134 ft/lb
Strut rod x Body 113 N/m, 1,150 kg/cm, 83 ft/lb
Strut rod x Rear axle carrier 113 N/m, 1,150 kg/cm, 83 ft/lb
Suspension member x Body 51 N/m, 520 kg/cm, 38 ft/lb
Suspension member lower stopper sub–assembly x Body 38 N/m, 390 kg/cm, 28 ft/lb
Stabiliser bar link set nut 39 N/m, 400 kg/cm, 29 ft/lb
Master cylinder x Piston stopper bolt 10 N/m, 100 kg/cm, 7 ft/lb
Master cylinder x Reservoir 1.7 N/m, 18 kg/cm, 16 in/lb
Master cylinder x Brake booster 13 N/m, 130 kg/cm, 9 ft/lb
Brake line union nut 10 mm nut 15 N/m, 155 kg/cm, 11 ft/lb
12 mm nut 20 N/m, 200 kg/cm, 14 ft/lb
Brake booster clevis lock nut 25 N/m, 260 kg/cm, 19 ft/lb
Brake booster x Pedal bracket 13 N/m, 130 kg/cm, 9 ft/lb
Brake pedal x Pedal bracket 39 N/m, 400 kg/cm, 29 ft/lb
Pedal bracket x Instrument panel reinforcement 13 N/m, 130 kg/cm, 9 ft/lb
Front brake caliper installation bolt 34 N/m, 350 kg/cm, 25 ft/lb
Bleeder plug 8.3 N/m, 85 kg/cm, 74 in/lb
Front brake torque plate x Steering knuckle 107 kg/cm, N/m, 1,090 79 ft/lb
Front brake caliper x Flexible hose 29 N/m, 300 kg/cm, 21 ft/lb
Flexible hose x Shock absorber bracket 29 N/m, 300 kg/cm, 21 ft/lb
Rear drum brake wheel cylinder x Backing plate 10 N/m, 100 kg/cm, 7 ft/lb
Parking brake cable bracket x Backing plate 7.8 N/m, 80 kg/cm, 69 in/lb
Rear brake caliper installation bolt 20 N/m, 200 kg/cm, 14 ft/lb
Rear disc brake cariper main pin installation bolt 26 N/m, 270 kg/cm, 20 ft/lb
Rear brake caliper x Flexible hose 29 N/m, 300 kg/cm, 21 ft/lb
Rear brake torque plate x Rear axle carrier 47 N/m, 475 kg/cm, 34 ft/lb
Proportioning valve installation bolt 8.8 N/m, 90 kg/cm, 78 in/lb
ABS actuator x Actuator bracket DENSO type 5.4 N/m, 55 kg/cm, 48 in/lb
ABS actuator x Actuator bracket BOSCH type 9.0 N/m, 92 kg/cm, 80 in/lb
ABS actuator x ECU BOSCH type 2.6 N/m, 27 kg/cm, 23 in/lb
ABS & TRAC actuator x Actuator bracket 5.4 N/m, 55 kg/cm, 48 in/lb
ABS (& TRAC) actuator bracket x Body 19 N/m, 195 kg/cm, 14 ft/lb
Front speed sensor installation bolt 7.8 N/m, 80 kg/cm, 69 in/lb
Front speed sensor harness clamp bolt 5.4 N/m, 55 kg/cm, 48 in/lb
Rear speed sensor installation bolt 7.8 N/m, 80 kg/cm, 69 in/lb
Rear speed sensor harness clamp bolt 5.4 N/m, 55 kg/cm, 48 in/lb
STEERING COLUMN
Steering wheel pad set screw (Torx screw) 7.1 N/m, 72 kg/cm, 63 in/lb
Steering wheel set nut 35 N/m, 360 kg/cm, 26 ft/lb
Intermediate shaft assembly x Control valve shaft 35 N/m, 360 kg/cm, 26 ft/lb
Steering column assembly x Intermediate shaft assembly 35 N/m, 360 kg/cm, 26 ft/lb
Steering column assembly set nut 25 N/m, 260 kg/cm, 19 ft/lb
Turn signal bracket x Column tube 7 N/m, 70 kg/cm, 61 in/lb
Lower column tube attachment x Column tube 19 N/m, 195 kg/cm, 14 ft/lb
PS VANE PUMP
Pressure feed tube x Control valve housing 5S–FE Engine 32 (25) N/m, 326 (250) kg/cm, 24 (18) ft/lb
Pressure feed tube x Pressure feed tube 1MZ–FE Engine 20 (25) N/m, 203 (250) kg/cm, 15 (18) ft/lb
Clamp plate set nut 5S–FE Engine 10 N/m, 100 kg/cm, 7 ft/lb
Clamp plate set nut 1MZ–FE Engine 7.8 N/m, 80 kg/cm, 69 in/lb
PS vane pump set bolt A bolt 29 (43) N/m, 293 (440) kg/cm, 21 (32) ft/lb
PS vane pump set bolt B bolt 43 N/m, 440 kg/cm, 32 ft/lb
Oil pressure switch x Union bolt 21 N/m, 210 kg/cm, 15 ft/lb
Union bolt x Pressure feed tube 52 N/m, 525 kg/cm, 38 ft/lb
Vane pump pulley set nut 43 N/m, 440 kg/cm, 32 ft/lb
Front bracket x Rear bracket 43 N/m, 440 kg/cm, 32 ft/lb
Suction port union set bolt 13 N/m, 130 kg/cm, 9 ft/lb
Pressure port union 83 N/m, 850 kg/cm, 62 ft/lb
Rear housing set bolt 24 N/m, 240 kg/cm, 17 ft/lb
PS GEAR
Pressure feed tube clamp plate set nut 10 N/m, 100 kg/cm, 7 ft/lb
Pressure feed and return tubes x Control valve housing 32 (25) N/m, 326 (250) kg/cm, 24 (18) ft/lb
Stabilizer bar set bolt 19 N/m, 195 kg/cm, 14 ft/lb
PS gear assembly set bolt and nut 181 N/m, 1,850 kg/cm, 134 ft/lb
Turn pressure tube union nut 10 (13) N/m, 102 (130) kg/cm, 7 (9) ft/lb
Rack x Rack end 60 (83) N/m, 615 (850) kg/cm, 45 (62) ft/lb
Rack guide spring cap lock nut 50 (69) N/m, 513 (700) kg/cm, 37 (51) ft/lb
Rack housing cap 59 N/m, 600 kg/cm, 43 ft/lb
Selt–locking nut 25 N/m, 250 kg/cm, 18 ft/lb
Control valve housing set bolt 18 N/m, 185 kg/cm, 13 ft/lb
Steering wheel 35 N/m, 360 kg/cm, 26 ft/lb
Steering wheel pad 7.1 N/m, 72 kg/cm, 63 in/lb
Front passenger airbag assembly x Instrument panel reinforcement 20 N/m, 205 15 ft/lb
Front seat installation bolt 37 N/m, 375 kg/cm, 27 ft/lb
Airbag sensor assembly 20 N/m, 205 kg/cm, 15 ft/lb
Front airbag sensor 20 N/m, 205 kg/cm, 15 ft/lb
Side airbag sensor assembly 20 N/m, 205 kg/cm, 15 ft/lb
2000 Camry LE 6-cyl, 77,000 - 230,000, traded it for a
2001 Camry XLE, 6-cyl, 87,000 - 120,000 and counting.
ajkalian is offline
The Following 2 Users Say Thank You to ajkalian For This Useful Post:
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
« Back
