DIY:Inner/Outer Tie Rod Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 15 Old 07-12-2011, 09:39 PM Thread Starter
Senior TN Member
Quoted: 226 Post(s)
(Thread Starter)
Disclaimer: Use this guide at your own risk! TN and I assume no responsibility for any damage to your vehicle or personal injury as a result of following this guide.
1.Engage the Parking Brake and block the rear wheels. Jack up the car and set it on Jack Stands.
2.Remove the front wheels.
3.Remove the cotter pins on the outer tie rods.
4.Loosen the outer tie rod about 3 threads.
5.Hit the steering knuckle under the outer tie rod until it pops out.
6.Count the threads on the inner tie rods. I wrote the amount of threads on the outer tie rods in sharpie.
7.Loosen the jab nut from the outer tie rod.
8.Remove the outer tie rod and jab nut.
9.Remove the clamps from the rack boot. The larger one needs to be broken. I used a long screwdriver and hammered the little clip until it broke.
10.Remove the boot.
11.Bend the lock tab out on the inner tie rod.
12.Loosen and remove the inner tie rods, I didn't have to use the special tool. They are not tight, an adjustable wrench and channel lock pliers worked fine. For the V6, on the driver's side I had to remove the air intake, on the passenger side the power steering pump had to removed and moved out of the way.
(Originals were trashed)
13.Install the new inner tie rods, I didn't install lock tabs, it was impossible for me to bend them so I bought red strength thread locker and put alot on the threads. Then tighten with an adjustable wrench.
14.Reinstall the rack boots, I used a worm gear clamp for the larger clamp, much easier to work with, install the smaller clamp too.
15.Install the jab nuts, make sure the amount of threads is the same number you wrote down.
16.Install the outer tie rods and try to get the wheels as straight as possible with the steering wheel.
17.Install the nut and cotter pin on the outer tie rods.
18.For the V6 install the air intake, ps pump and belt.
19.Torque the wheels to specs.
20.Go for a test drive and enjoy the new tight steering and no clunking.
21.Don't forget to get an alignment.
pmesfun is offline
The Following 3 Users Say Thank You to pmesfun For This Useful Post:
Brit101 (12-18-2011), fenixus (12-15-2011), Yuko (12-15-2011)
post #2 of 15 Old 12-15-2011, 10:49 AM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
nice, steps sound clear, but more pics would help a lot
so what was the problem with installing the lock tabs on new inner tie rods?
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
post #3 of 15 Old 12-15-2011, 04:53 PM Thread Starter
Senior TN Member
Quoted: 226 Post(s)
(Thread Starter)
I did this awhile ago, so I can't get more pictures. After you take off the rack boots the rest is self explanatory.
For the lock tabs, I couldn't get enough room to bend all of the tabs so I just put red loctite, its been half a year with no issues. I guess you could bend the tabs on oem tie rods because they only have 2 flats versus the 4 on the Deezas I installed.
pmesfun is offline
The Following User Says Thank You to pmesfun For This Useful Post:
post #4 of 15 Old 12-15-2011, 09:55 PM
The Tri-Camry Family
Yuko's Avatar
Quoted: 14 Post(s)
Nice DIY
I tried to replace the inner tie rod on my Grandmother's 02' Camry. Very similar but there was no flat spot on the inner tie rod to use a wrench. I wish Toyota kept the old design instead requires a special tool.
"Yūko" 2001 Camry 5S-FE/A140E @ 130k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 180k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 80K
Yuko is offline
post #5 of 15 Old 12-17-2011, 09:44 PM
セクシーの定義
Quoted: 0 Post(s)
Hey guys,
Just re-newed the steering gear dust boot and I'm in the process of assembling it together. Problem is, the outer tie rod end stud keeps spinning when i try to tighten the castellated nut. I tried lightly tapping the tapered end further in, but now it just pops back out of the taper and the stud starts to spin.
Any help or ideas?
Camry history:
1990 Camry CS 5spd - Now scrap metal
1994 Camry Executive A/T - Burnt to a crisp.
1995 Camry Vienta Csi A/T - Still running
1999 Camry Touring 5 spd - Current
Jimnist is offline
post #6 of 15 Old 12-17-2011, 10:06 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
replace it.
fenixus is offline
post #7 of 15 Old 12-18-2011, 02:48 AM
セクシーの定義
Quoted: 0 Post(s)
Did a quick google search and it's normal for it to spin. I gave it a bit more persuasion with the hammer and the taper locked it in place.
Camry history:
Jimnist is offline
post #8 of 15 Old 10-17-2012, 04:38 PM
Senior TN Member
Quoted: 25 Post(s)
is this the correct part?
i ran the p/n and it came back at like 30$ which seems too cheap to the the right part for the whole rod and stuff in the dust boot
45047 END SUB-ASSY, TIE ROD, LH
45046-09020 1 $64.04
Replaced by: 45046-29255
38.90$
going by toyotapartszone.com
If you find my post helpful, please use the button
adalex is offline
post #9 of 15 Old 10-21-2012, 09:47 AM
Quoted: 0 Post(s)
jam nut size
what size wrench is needed for the jam nut?
siriusalpha is offline
post #10 of 15 Old 10-21-2012, 07:50 PM
Senior TN Member
Quoted: 25 Post(s)
not sure, i ordered a moog inner tie rod from rockauto, should be here sometime later this week, if u don't figure it out by then ill let u know. p/s what part of fl u in?
adalex is offline
post #11 of 15 Old 10-21-2012, 07:58 PM
Chris Crash's Avatar
Quoted: 30 Post(s)
iTrader Score: 13 reviews
I think it's a 14 mm. Just go try and find out!
2016 Toyota Corolla S Plus 6-speed
2015 Dodge Ram 1500
1997 Toyota Camry LE 5-speed
1994 Toyota Camry J-Vin
1997 Toyota Camry CE 5-speed
Chris Crash is offline
post #12 of 15 Old 10-21-2012, 07:59 PM
Quoted: 0 Post(s)
Jam nut
Need the jam nut size for the outer tie rod........from orlando
post #13 of 15 Old 10-21-2012, 08:10 PM
Quoted: 30 Post(s)
2015 Dodge Ram 1500
post #14 of 15 Old 10-21-2012, 08:48 PM Thread Starter
Senior TN Member
Quoted: 226 Post(s)
(Thread Starter)
Yeah, 14mm IIRC.
pmesfun is offline
post #15 of 15 Old 10-24-2012, 11:53 AM
Senior TN Member
Quoted: 25 Post(s)
success, i had ordered inner tie rod from rock auto but it won't be here till friday, when i loosened the castle nut i noticed grease under the rubber boot on the tie rod end, i went to advance and got a moog inner tie rod as well as the tool (which helped me so i could torque it to spec. i went and got the moog tie rod end and well it was shot too
original inner tie rod and lock washer that i had to deface to bend the taps back LOL
i need to get an alignment today since my steering wheel sits facing 9 o clock when going straight and pulls hard right if i try and straighten the wheel :P
adalex is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
