1999 Camry Timing Belt Replacement - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 11 Old 08-13-2011, 05:58 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello,
New to the forums and had a question about timing belt replacement. Me and my father have the belt on, but still think the the timing is off. I was wondering if anyone had any high resolution pictures of the timing marks on both the crankshaft and camshaft. I have a haynes manual, but we couldn't find a pic of what to look for as far as marks. Car will not start, but do have spark. Any help is appreciated. Thanks!
jd84 is offline
post #2 of 11 Old 08-13-2011, 06:01 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
This is a 4 cylinder engine by the way.
jd84 is offline
post #3 of 11 Old 08-13-2011, 06:03 PM
Toyota Collector
71Corolla's Avatar
Quoted: 1256 Post(s)
DIY: GEN3 Timing Belt + Waterpump + Oil Seal Change - Part 2
Parts For Sale
2000 Lexus ES300 Millenium Edition
1993 Camry V6 LE
1990 Camry LE V6
1990 Camry LE V6 WAGON
1987 Camry LE I4
71Corolla is online now
post #4 of 11 Old 08-13-2011, 06:06 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks alot! We did have them right it seems. We lined up the crankshaft to the 0 on the cover. Then lined up the cam with the hole. Any ideas why it still wont crank?
jd84 is offline
post #5 of 11 Old 08-13-2011, 07:57 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
One more thing to check, if you have everything lined up, as in the picture above, is any noticeable slack in the belt. Slack will be obvious, probably on the lower side between the cam pulley and the crankshaft. Just retract the tensioner and shift the belt teeth one or two places ... until the topside and bottom-side of the belt have little or no slack.
Check your alignments one more time ...
This is a seemingly minor detail, but I think it makes a difference in your engine performance.
... Not too sure why it won't start ... are you sure that you have the correct mark on the cam shaft in line with the cam sprocket hole?
former owner 98 Camry LE, 2.2L, automatic
54k miles, drop in K&N A/F, ... timing belt, water pump, NSS
dc_98_cam is offline
post #6 of 11 Old 08-13-2011, 07:59 PM
2001 Camry XLE 1MZ-FE
Quoted: 41 Post(s)
Be sure you line up the hole in the camshaft, with the right hole, not the dimple. You can see the one whole through the hole in the camshaft, but if you look at the far right edge of the mirror, about in the middle, you will see a dimple. If you line this dimple up with the hole in the camshaft, the timing will be incorrect. Make sure that your's looks exactly like the picture.
Edit:
If the above seems a bit confusing, then refer to the photo below.
2000 Camry LE 6-cyl, 77,000 - 230,000, traded it for a
2001 Camry XLE, 6-cyl, 87,000 - 120,000 and counting.
ajkalian is offline
post #7 of 11 Old 08-13-2011, 08:00 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
^+1
post #8 of 11 Old 08-13-2011, 08:43 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Edit:
We were using that marker at first, but then realized we needed to be using the other one. Even used a screwdriver with a pick end to go through to make sure it lined up behind. We ended up not being able to find the markings for the crankshaft so we had to put the cover back on and line it up with the numbers on the cover.
jd84 is offline
post #9 of 11 Old 08-14-2011, 04:37 AM
Senior TN Member
Quoted: 431 Post(s)
Once the marks were lined up you were supposed to rotate crank at least two revolutions and re-check alignment of marks. Double check your work by making sure the marks line up on TDC Compression. If you have a timing light you can also check spark timing while cranking to confirm cam/crank alignment.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 233K
Stillrunning is offline
post #10 of 11 Old 08-14-2011, 08:46 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks for all of the info so far. I believe we did the 2 revolutions to check the alignment marks again. One thing we did wrong at first was not hooking up the cam shaft sensor and ground wire. Once we hooked that up we were getting spark, but still not firing. Do you all think the timing is still off? Or could it be something small that we are still overlooking? I really appreciate all of the feedback so far.
jd84 is offline
post #11 of 11 Old 08-14-2011, 11:13 AM
Senior TN Member
Quoted: 431 Post(s)
Spark not on compression stroke will not start engine. Are you getting fuel?
Spark, Compression, Timing, Air, Fuel - you need all.
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
