Is Powersteering Fluid the Same as Transmission Fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 20 Old 10-25-2011, 03:03 AM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
Hi All,
I have a stupid question and I apologize in advance.
In my 1992 LE v6 Camry, I was told by kid behind the counter of a local autoparts store that I can use transmission fluid for my powersteering, but not vice versa, is that correct?
Thanks!
dutd33 is offline
post #2 of 20 Old 10-25-2011, 04:02 AM
96 es300 2mz-fe
Quoted: 0 Post(s)
No, they are not the same. I would say most cars use psf in there steering system but your Camry uses atf in it's steering system. The required fluid for the steering should be on the power steering reservoir cap.
00 Solara SE 1MZ S/C Current
97 Camry LE 5SFE Current
01 Solara SE 1MZ S/C Sold
99 Solara SE 1MZ 5SPD Sold
96 ES300 2MZ 4AT Sold
Brandoe91 is offline
The Following User Says Thank You to Brandoe91 For This Useful Post:
dutd33 (10-25-2011)
post #3 of 20 Old 10-25-2011, 07:29 AM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 367 Post(s)
Wink
Thanks!
Yes, the Toyota vehicles use Dexron II or better (aka ATF) fer the power steering fluid. Read the cap on yer power steering reservoir...
Why is yer PS fluid low?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline
The Following User Says Thank You to BamZipPow For This Useful Post:
dutd33 (10-25-2011)
post #4 of 20 Old 10-25-2011, 01:13 PM Thread Starter
Quoted: 1 Post(s)
(Thread Starter)
OK cool, I've purchased some ATF.
I don't know why it's low, but it's not that low... just a tiny bit below the MIN. line.
Thank you everyone for their help!
dutd33 is offline
post #5 of 20 Old 10-25-2011, 05:16 PM
Quoted: 0 Post(s)
I don't get it, if they recomend ATF in the power stearing, why has the last 6 Toyota's I have purchased (92,94,2000,2001,2011x2) come with clear fluid in the powerstearing that does not smell or feel like ATF???? And why does the dealer even sell power stearing fluid??
My 94 camry had the stearing rack changed by the dealer in 03 and it got refilled with clear fluid.
I've read it in the manual and seen it preeched on the internet but I've never seen a toyota with pink power stearing fluid, atleast one that came out of a dealer. I'd like to change my fluid but I'm not sure what to put in.
Am I missing something??
D
Make that 7 Toyotas, I forgot about the Tundra
Doug S is offline
post #6 of 20 Old 10-25-2011, 05:35 PM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
iTrader Score: 8 reviews
V6 uses ATF , 4 Cylinder uses Power Steering
Perkins is offline
post #7 of 20 Old 10-25-2011, 05:57 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
errr, all camry and solara owner's manuals I read said Dexron II/III compatible for PS and Dexron-II/III compatible for trans (and auto differential)... with exception to transmission calling for Type T-IV fluid (coupled with newer 2az-fe engines)
both Solaras came with a clear ATF (called Toyota power steering fluid) in PS tank, both res caps say same (on both V6 and 4cyl) Dexron-II/III...
I use the same ATF for the PS as I use in trans (and auto diff) that would be either Castrol IMV or Mobil1 ATF.
maybe gen3 was different? I am holding a 2000 camry owner's manual in my hand and it says (per checking PS fluid level, page 229):
"Check the fluid level through the reservoir. If necessary, add automatic transmission fluid Dexron-II or III"
'02 Solara SLE V6 1MZ-FE/A541E@ 154k
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." - Aristotle
fenixus is offline
post #8 of 20 Old 10-25-2011, 05:59 PM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
If you simply open up your Owners manual, It will specify what fluid is correct for your application as well. Its as easy as that. lol
Perkins is offline
post #9 of 20 Old 10-25-2011, 06:00 PM
Senior TN Member
Quoted: 431 Post(s)
My I4 owner's manual specs DexII. Just check your owners manual.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 233K
Stillrunning is offline
post #10 of 20 Old 10-25-2011, 06:00 PM
Turbo Snail
Perkins's Avatar
Quoted: 5 Post(s)
lol , yeah maybe i should. I've been putting power steering fluid in my camrys for years. Whoops
I guess i just ate my own words!
Perkins is offline
post #11 of 20 Old 10-25-2011, 06:10 PM
Quoted: 0 Post(s)
Thanks for that but I'm more confused:
92 V6 4runner
94 V6 Camry
2000 V6 Sienna
2001 V6 4runner
2001 V8 Tundra
2011 V6 Camry SE
2011 V6 Camry XLE
I'm not being a wise guy or anything-(sorry I hijacked the thread), I just would like to get it straight, I'd like to change the fluid in the 01 4runner.
Thanks
d
Doug S is offline
post #12 of 20 Old 10-25-2011, 06:16 PM
Quoted: 0 Post(s)
I know it's in the manual, I just wonder why Toyota-(factory) or the Dealer don't use ATF.
Has anyone seen a Toyota come new with ATF-(pink) in it or had the stearing pump or rack replaced at the dealer and have the dealer use ATF?
Thanks
D
Doug S is offline
post #13 of 20 Old 10-25-2011, 06:51 PM
抵抗は無駄です
fenixus's Avatar
Quoted: 9 Post(s)
does the color and smell mean so much to you? both clear toyota fluid and regular red ATF must be dex-iii compatible, so why bother?
fenixus is offline
post #14 of 20 Old 10-25-2011, 09:06 PM
Senior TN Member
Quoted: 226 Post(s)
I swapped out the fluid in the power steering reservoir in our 07 avalon with Dexron ATF with no problems, actually the steering is much smoother now. The original fluid was black and smelt like crap, same with the 99.
pmesfun is offline
post #15 of 20 Old 10-25-2011, 11:39 PM
The Tri-Camry Family
Yuko's Avatar
Quoted: 14 Post(s)
I posted this on a different thread.
"After hours of researching on other Toyota forums, it is highly NOT recommended to use generic power steering fluid in a system that requires Dexron III ATF. Even thou the color of the generic fluid and store brought power steering fluid is the same light amber, the chemical make-up is different and is known to cause seals to leak and pumps to fail. Most Toyota dealerships do sell there own P/S fluid which is nothing more than Dexron III without the dye and smell. One reason why the colors are different even thou the fluid is the same is to detect leaks easier between the P/S system and the transmission."
I'm planning to change out my P/S fluid in my Gen 4 with some Valvoline Maxlife Dex/Merc ATF. It's making some strange noise at full lock that I never heard before.
"Yūko" 2001 Camry 5S-FE/A140E @ 130k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 180k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 80K
Yuko is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
