car only leaks power steering fluid in cold weather - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 10-29-2011, 05:00 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Last winter, my 1998 Camry started leaking power steering fluid at a very slow rate. I kept an eye on the levels and only had to add a tiny bit of fluid every week or two. Once the weather warmed up in the spring and summer, the car stopped leaking power steering fluid completely. My car is once again leaking power steering fluid at a slow rate now that the weather is turning cooler. Why does the temperature have an effect on how quickly the power steering fluid leaks?
Last winter, I took the car into two different mechanics to get estimates on fixing the problem. One mechanic said that only the pump needed to be replaced and the other mechanic said the rack and pump were both faulty. I do not know who to believe and didn't want to pay another mechanic for a diagnostic fee. Since the leak is very slow and I am not experiencing any steering noises or problems, which is the most likely cause for my leak? Is there any risks associated with using Lucas Stop Leak or similar products? I can afford to replace the pump but replacing the rack and pinion is too costly. I do not like the mess the leak is making in my garage so I'd like to do something to slow the leak or stop it. Any advice would be appreciated.
"twocamrys"
1998 Camry LE 4 cylinder (106K)
1996 Camry LE - SOLD
twocamrys is offline
post #2 of 8 Old 10-29-2011, 05:29 PM
Senior TN Member
carsrus's Avatar
Quoted: 171 Post(s)
Cold weather = seals contract.
Suck out everything the reservoir and fill it with Lucas power steering stop leak. The stuff works miracles.
carsrus is offline
post #3 of 8 Old 10-29-2011, 06:36 PM
イリジウム
Quoted: 249 Post(s)
It's always a good ideal to siphon out the PS fluid in the reservoir and refill with new ATF once a year or every other oil change. This keeps the junk in the fluid low so the ATF doesn't become too abrasive.
If Lucas PS Stop Leak helps, then just run with it. Otherwise you should be able to see where the ATF is leaking and tell if only the pump or the rack body need replacing. There is also a PS pump seal kit for about $20 if you can rebuild your own. This kit of course doesn't include the pump shaft if a groove is worn into it by the seal spring.
I'd recommend refilling the reservoir with Mobil-1 (use Advance Auto coupon code to get it close to $5.6/qt). Or use Walmart SuperTech Mercon-V. It's better than plain dino Dexron III.
Lucas:
http://www.lucasoil.com/products/dis...tid=9&loc=show
JohnGD is offline
post #4 of 8 Old 12-27-2011, 04:09 PM
Quoted: 0 Post(s)
twocamrys,
I have the same problem with my 1998 Camry V6. Power Steering leaks only in winter. Lucas stop leak is of no help. What did you end up doing?
aj_s21 is offline
post #5 of 8 Old 02-09-2014, 08:16 PM
Quoted: 0 Post(s)
My 1997 Camry XLE V6 (264 000km) leaks as well. Last winter I discovered one day my PS reservoir was nearly empty. The lines to and from the tank were a little greasy. Toyota refilled it and said that it might be a good idea to replace the pump. However, the weather started warming up and there was no change in the PS fluid level.
This winter it started leaking again, but this time I noticed that the area around my driver side steering rack boot was very greasy, and leaking PS fluid from somewhere around there. I check it every few weeks and top off the fluid.
So I don't really want to spend the money on replacing the PS pump or steering rack as I am replacing the vehicle within the 15 months or so.
Is it possible that the extreme cold weather makes the leak worse by contracting the metal/rubber parts? I park in a heated garage, so the vehicle goes through a lot of warn/cold cycles.
I am hoping the steering rack and PS pump will survive (with me topping up the fluid) until I am ready to buy a new vehicle.
Any input appreciated, thanks!
kevlo86 is offline
post #6 of 8 Old 02-09-2014, 09:22 PM
Senior TN Member
dc_98_cam's Avatar
Quoted: 110 Post(s)
My 98 Camry had a slow leak at about 45 kmiles. I made a determined effort to complete several drain, drive, and refill cycles. ... Just drain the PS reservoir bottle on the fender, and refill with clean fluid. The leak has completely disappeared.
I used two or three different PS fluids ... one had some sort of teflon.
I think it important to use something with an additive of some sort.
Now, I regularly drain and refill at every oil change ... once a year. I buy a Toyota dealer recommended PS fluid ... at the Toyota parts counter. It was said to be fine for any Toyota PS system.
I think you can extend the life of your PS system, if there is not a major problem.
former owner 98 Camry LE, 2.2L, automatic
54k miles, drop in K&N A/F, ... timing belt, water pump, NSS
dc_98_cam is offline
post #7 of 8 Old 02-10-2014, 02:09 AM
Account canceled
Quoted: 17 Post(s)
With such a minor leak, put a tray under the car, even a sheet of cardboard on the garage floor.
matt1mzfe is offline
post #8 of 8 Old 02-10-2014, 08:20 AM
Darkside Cut Me!!!
Quoted: 3 Post(s)
I used Lucas hydraulic booster and stop leak in the entire system, (it is same as the P/S stop leak but less expensive and without the red dye).
I had a corroded supply line that was leaking badly, ATF just dribbled out.
Steering will be stiff for the first minute or so in the cold weather, but once it circulates, it will be fine.
2004 RX330 Sport
2004 Matrix XR
1998 CamCE I4 Super Commuter!
1997 CamLE I4
Gone:
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
Hajoca is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
« Back
