Move timing belt 1 notch - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 3 Old 12-02-2011, 03:23 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
3rd Generation Move timing belt 1 notch
Anybody have an easier way to move the timing belt one notch on one of the camshaft sprockets?
Thanks
buercky is offline
post #2 of 3 Old 12-02-2011, 04:33 PM
Senior TN Member
Quoted: 428 Post(s)
Easier way than what? You'll have to try and take the slack out of the belt.
1995 Camry Wagon LE. 2.2 5S-FE, Auto, 233K
Stillrunning is offline
post #3 of 3 Old 12-02-2011, 08:04 PM
イリジウム
Quoted: 252 Post(s)
I take it that you're trying to leave the crank pulley in place and just work on the cam alignment?
The tensioner has to come off on both the I4 and V6 to give you enough slack. After that, on the V6, you either remove the belt from the rear bank or loosen/remove the idler. The idler may be difficult to put back if you loosened/removed it and there wasn't enough slack however.
But the key when it's a little off is to use a breaker bar and socket to rotate the cam sprocket to help align the belt while it's loose, instead of moving the belt itself.
And when you are all done, reinstall the tensioner, rotate the crank 2 revolutions and double check the timing marks.
Thanks
JohnGD is offline
The Following User Says Thank You to JohnGD For This Useful Post:
buercky (12-03-2011)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
