Changing '99 solara V6 Gaskets - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 4 Old 01-05-2012, 12:09 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Unhappy Changing '99 solara V6 Gaskets
Hi Every1, I'mma noob.. and would Really Need help to change the following:
1. Valve cover gaskets
2. Spark Plugs
3. Intake manifolds
on my V6 '99 Solara.. By Reading many threads.. please correct me if i'm wrong.. By changing the Rear Valve Cover Gasket.. I DO indeed have to pull of the intake manifold.. Correct..?
If so, I'm planning to just change all of these and get it done with.. What I'm really asking is that.. How do I get to the Rear Valve Cover Gasket..? Please Help.. Any suggestions would be great.. .. Thank You guys..
kphongx is offline
post #2 of 4 Old 01-05-2012, 01:42 AM
Senior TN Member
Quoted: 226 Post(s)
Yes, you have to remove the intake plenum, along with the valve cover gasket, it is a good idea to replace the spark plug tube seals, intake plenum gasket and the pcv valve and grommet. Once you get the intake plenum, and egr pipe removed all that is left is to move the wiring harness out of the way(kind of a pain) and remove the bolts that hold on the valve cover.
pmesfun is offline
The Following User Says Thank You to pmesfun For This Useful Post:
kphongx (01-05-2012)
post #3 of 4 Old 01-05-2012, 09:50 AM
2001 Camry XLE 1MZ-FE
Quoted: 41 Post(s)
You said you had read some threads on how to change the Valve Cover Gaskets. Here's some more for you to read in case you missed them.
Here is Pmesfun's epic thread. It's 12 pages long, but you should read the entire thread.
http://www.toyotanation.com/forum/10...ed-advice.html
Here's another one:
http://www.wjowsa.com/carstuff/toyot...lve-cover-job/
page 2
http://www.wjowsa.com/carstuff/toyot...job/?nggpage=2
Here's one by BMR:
http://www.toyotanation.com/forum/10...ets-today.html
Here's info on the lame bolts that hold the valve cover.
More on the valve cover bolts:
http://www.toyotanation.com/forum/10...er-gasket.html
That should be enough get you started, now get to work.
2000 Camry LE 6-cyl, 77,000 - 230,000, traded it for a
2001 Camry XLE, 6-cyl, 87,000 - 120,000 and counting.
ajkalian is offline
The Following User Says Thank You to ajkalian For This Useful Post:
post #4 of 4 Old 01-05-2012, 10:31 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thank You Both for your guy's quick response.. .. U both are my savior.. once I actually become a Dr. I'll give u guys free checkups. ... Thanx Again.. God Bless.. -kphongx
kphongx is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
