1992 Camry rough idle - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 8 Old 04-01-2012, 05:54 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hello everyone, I need some help, please.... My neighbor is selling his brother's 1992 Camry 2.2L DLX, he wants $400 for. He tells me that the car runs good, with the exception that it doesn't want to idle.
It appears that the plug that comes off of, what i think is the throttle body, has been cut. Should i connect the wires back up to the plug??
any info you can give will be deeply appreciated.
JIMDE is offline
post #2 of 8 Old 04-01-2012, 11:07 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 674 Post(s)
A picture would really help.
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #3 of 8 Old 04-02-2012, 12:46 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
A picture would be the way to go except for that i don't the capability to take pictures with phone nor do i have a camera. Thanks for your help, though.
JIMDE is offline
post #4 of 8 Old 04-02-2012, 09:14 AM
Quoted: 0 Post(s)
then I would have to assume that any plug that is supposed to be there should be fixed. reattaching the wires would be a good place to start.
you have 2 plugs going to the throttle body; the TPS (throttle position sensor) and the IAC (idle air control). you need to have both of those attached
also, the TPS could be bad, or the IAC could be clogged.
'93 camry 4cyl, 290K+ miles, gets me to work everyday, that makes it AWEsome!
mpvue is offline
post #5 of 8 Old 04-02-2012, 10:24 AM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 674 Post(s)
No prob; I just hate guessing. Since you said it won't idle, the IAC cable would be a very good guess. Here's a thread showing how to clean the IAC; there are some pics in there that might help you figure things out. In the very first pic he's pointing at the IAC connector. Is that the one you're talking about?
BMR is offline
post #6 of 8 Old 04-02-2012, 12:52 PM
T100 Road Warrior...
BamZipPow's Avatar
Quoted: 367 Post(s)
Describing as much as you can to a blind man can really help here.
What colors are on the wires?
How many wires?
What order is the wires?
Where does the plug connect to?
1998 T-100 SR5 2WD auto, Roadmaster Active suspension, oil catch jar, AC mod, aero cap, lower aero package, 67% grill block
BamZipPow is offline
The Following User Says Thank You to BamZipPow For This Useful Post:
JIMDE (04-02-2012)
post #7 of 8 Old 04-06-2012, 05:05 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Idle problems
THANKS FOR THE HELP!
When I checked the resistance on the IACV nothing registered. So I'm figuring that the one i have is bad. When I called the parts store they told me that you have to buy the whole thing..$239.00. What do you think about getting a used one?
JIMDE is offline
post #8 of 8 Old 04-06-2012, 05:38 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 674 Post(s)
I'd go for a used one. They often get clogged up, but they don't often break. So if you go used, just clean it up really good, like those DIY threads show.
BMR is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
« Back
