Denso IK20 intervals - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 17 Old 10-04-2012, 03:37 AM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
When to change these?
I had them installed around
135,000kms
now 190,000kms
I guess these last 100,000kms?
No misfires and high mpgs.
1997 3Gen Toyota Camry 5SFE
Denso IK20 Iridium 0.4mm
Green racing air filter
Km/h and MPH dual speedometer
Shell Helix Ultra Racing 10w60 SN/CF
camry_RHD is offline
post #2 of 17 Old 10-04-2012, 07:36 PM
イリジウム
Quoted: 252 Post(s)
I'd pull and inspect the plugs now.
Denso's iridiums have a thinner center electrodes than NGKs. NGK Iridium-IX can go 60-75K miles (96-120K km) without problems. The wear will be on the ground electrode as the softer metal erodes away. NGK Laser Iriduims have platinum ground pads that just about eliminate this wear. (Toyota spec them 120K miles/193K km).
I would check the Denso at 30K miles (48K km) and decide from there, and see if you can run them for 45K miles (72K km). I don't think they'll last as long as NGKs.
Apply a small dab of spark plug antiseize 3 threads away from the tip when you reinstall. Use a torque wrench to 13 lb/ft (18 Nm).
Your plugs may go more, but Denso actually recommends 30K mile (48K km) replacement.
http://www.densoiridium.com/faq.php
JohnGD is offline
post #3 of 17 Old 10-05-2012, 06:25 AM
1MZ powered MR2
Jason.MZW20's Avatar
Quoted: 0 Post(s)
The IK20s are high performance iridium plugs with a small 0.4mm electrode. Denso rates these at 60k miles.
However, before I knew this, I ran them in my mom's 2000 Camry 5SFE and they lasted 120k miles in a wasted spark setup. Guess what happened? The ground electrode wore down to almost nothing but the iridium electrode still looked brand new. These plugs, then, are ground electrode limited.
If you want a longer lasting Denso iridium plug, look into the SK20R11; these have a 0.7mm iridium tip with a platinum ground. Unfortunately, Denso doesn't make the twin tip FK20HR11 for non-long reach engines.
1991 Toyota MR2 V6
Ported, rebuilt MY2000 3.0L 1MZ
Fully OBDII compliant and California smog legal
Jason.MZW20 is offline
post #4 of 17 Old 10-07-2012, 07:55 AM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
May I see those plugs at 120,000mls intervals?
What do you mean with a wasted spark setup?
Mine look like this now:
post #5 of 17 Old 10-07-2012, 01:14 PM
イリジウム
Quoted: 252 Post(s)
That's a good bit of deposit at about 34K miles. Usually at this mileage the iridium plugs would look almost new. I've seen 100K+ plain platinum plugs that looked better. Looking at the gasket - it's a bit hard to tell but is it still round? Was it torqued to 18 lb/ft (dry) or 13 lb/ft with a dab an antiseize? Because with NGK gaskets they would look flat, almost like two flat washers stacked together.
Yeah, it's time to change these plugs, but I'd want to find out why the plugs look so worn at this km/mileage.
A waste-spark system is an old design that manufacturers use to save on extra coils. 2 cylinders are paired together and their plugs fired at the same time. Since one cylinder will be on the combustion cycle and the other on exhaust, the spark in the exhaust cylinder is therefore "wasted". Plugs worked twice as hard in the waste-spark system. The system worked, but manufacturers have since moved away from it. Maybe only to claim a longer plug change interval? Or does the wasted spark lowered the spark energy in the primary cylinder? Dunno.
JohnGD is offline
The Following User Says Thank You to JohnGD For This Useful Post:
camry_RHD (10-07-2012)
post #6 of 17 Old 10-07-2012, 01:23 PM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
A waste-spark system is an old design that manufacturers use to save on extra coils. 2 cylinders are paired together and their plugs fired at the same time. Since one cylinder will be on the combustion cycle, the other on exhaust. The spark in the exhaust cylinder is therefore "wasted" and plugs worked twice as hard - therefore "waste-spark" system. The system worked, but manufacturers have since moved away from it. Maybe to claim a longer plug change interval? Dunno.
The tip is not off. Was the same as I checked at 150,000km. Nothing changed till now tip and gap still same. I would stay a while with these till 230,000 km.
These are the IK20 0.4mm and can last only 30,000km they say.
Maybe next time try IK22? These look too hot to me (Temp range 5).
post #7 of 17 Old 10-07-2012, 01:44 PM
イリジウム
Quoted: 252 Post(s)
Or maybe give NGK Iridium-IX or Laser Iridium a try.
JohnGD is offline
post #8 of 17 Old 10-07-2012, 01:47 PM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Is Denso IK22 possible to have in a 5SFE NA?
Or do I need the same one aka IK20?
post #9 of 17 Old 10-07-2012, 02:04 PM
イリジウム
Quoted: 252 Post(s)
I don't know enough about changing heat ranges, but for turbo some may use a cooler plug. Maybe others can chime in here.
JohnGD is offline
post #10 of 17 Old 10-07-2012, 02:09 PM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Just one heat range higher can't really affect engine operation I guess.
Will be trying IK22 and see what happens.
post #11 of 17 Old 10-08-2012, 02:23 AM
1MZ powered MR2
Quoted: 0 Post(s)
I beg to differ.
Changing heat ranges adds/removes 70-100*C from the combustion chamber for each heat range. 1-step colder will remove 70-100*C, which is equivalent to 10* of ignition retard.
I fail smog with the 1MZ's stock heat range. I pass smog with 1-step hotter plugs. The hotter plugs cut HCs (unburned fuel) roughly in half (108ppm to 53ppm; passing is 54ppm). The CA ECU I have runs richer during the 15mph test because it expects pre-catalysts (don't have them) and uses the fuel to keep them hot.
If the porcelain were WHITE, the plug would be too hot. It looks fine (pink to dark pink is good). The rest of the deposits can be from poor fuel quality.
I hope I still have them. If I don't, just imagine the tip of the ground electrode completely worn down. I had to push the ground electrode inward and down toward the tip to reduce the gap and prevent misfires while I waited for the SK20R11s.
Wasted spark is the type of direct ignition system the 1997-2001 5SFE uses. It pairs cylinders 1-4 and 2-3 on the same coil/igniter assembly (2-wires are attached to each coil/igniter). So when cylinder 1 fires in the power stroke, cylinder 4 also fires (very weakly) in the exhaust stroke. That's the basic premise.
1991 Toyota MR2 V6
post #12 of 17 Old 10-08-2012, 06:46 AM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
I beg to differ.
Thanks will try IK22 on this car.
post #13 of 17 Old 10-08-2012, 08:55 PM
1MZ powered MR2
Quoted: 0 Post(s)
Why? The stock heat range is fine. You'll lose power with the IK22s because the 5SFE ECU doesn't have aggressive ignition timing maps.
1991 Toyota MR2 V6
post #14 of 17 Old 10-09-2012, 12:31 AM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
For me those plugs look fine because after 10,000km of use still same colour and wear as now 60,000km later.
Next time IK20 then.
post #15 of 17 Old 11-01-2012, 10:39 AM Thread Starter
RHD is cool
camry_RHD's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Jason btw I have been running 94 octane (98 RON only since I bought it).
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
