1999 Toyota Camry V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 5 Old 11-09-2012, 03:03 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have error codes P0125 and P1155. What do I do to cure them.
jtavitian is offline
post #2 of 5 Old 11-10-2012, 12:24 PM
Stilkiboy
Quoted: 4 Post(s)
Might get better chance for an answer in the Camry forum...
-98 Camry 2.2 5S-FE
-96 Carina E 1.8 7A-FE
-96 Carina E 1.6 4A-FE
-85 Suzuki SJ 413 G13A (FK-Balja)
-86 Suzuki SJ 413 G13A
-84 Suzuki SJ 410 F10A
Dotsetsveen is offline
post #3 of 5 Old 11-10-2012, 05:17 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 665 Post(s)
I moved your thread to the Gen 3/4 Camry forum.
P0125 = Insufficient Coolant Temperature For Closed Loop Fuel Control
Could be the thermostat is stuck open, or the coolant temperature sensor has gone bad. Does the temperature gage on the instrument cluster show the temperature is about halfway between hot and cold? If it's running too cold, it's probably the thermostat.
P1135 = Air/Fuel Sensor Heater Circuit Response. (Bank 1 Sensor 1)
That's the sensor in the rear bank's exhaust manifold. Here's a DIY thread showing how to replace it: http://www.toyotanation.com/forum/10...placement.html
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
post #4 of 5 Old 11-11-2012, 04:12 AM
Quoted: 65 Post(s)
Fix the P1135 and the P0125 will go away. Is your car CA emissions? If yes it takes the more expensive air/fuel sensor. Your car is not going into closed loop (hence the P0125) because of your malfunctioning B1S1 sensor. Very common problem.
artbuc is offline
post #5 of 5 Old 12-19-2012, 10:59 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
« Back
