Engine not starting after replacing distributor. - Toyota Nation Forum : Toyota Car and Truck Forums
Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001) Toyota Camry Discussion for years 1992-1996 & 1997-2001, as well as Solara discussion for years 1999-2001. Topics of discussion range from fuel economy, safety, modifications, performance all involving America's favorite family car, the Toyota Camry.
post #1 of 2 Old 03-17-2013, 03:50 PM Thread Starter
Quoted: 10 Post(s)
(Thread Starter)
Hi guys.
My 1993 Toyota Camry 2.2L LE has been having a hard time turning over. I recently put a brand new starter in it. Even after that, I would have to attempt to crank it 4 or 5 times on occasion before it would turn over.
Yesterday, I replaced the whole distributor, plugs, and wires. I properly timed it with a timing light and the car seemed to be doing much better, as I drove it home with no problem and much better/easier acceleration.
The distributor I pulled out of it seemed to have oil leaking into it pretty badly. As far as I could tell it was shot.
After sitting overnight the starter is just turning continuously, and the engine will not crank. It seems like it starts to turn over for a second but won't turn over all the way, and then the starter just keeps turning.
ANY help/suggestion is greatly appreciated, thanks.
EDIT: I tried pulling a code from the obd1 and I believe I'm getting code 22, which reads as: 22 Engine Coolant Temperature Sensor signal. Could this cause the engine not to turn over?
'93CamryGuy is offline
post #2 of 2 Old 03-17-2013, 04:34 PM
BMR
Sheriff of Mayberry
BMR's Avatar
Quoted: 665 Post(s)
Try disconnecting the ECT. I doubt that's the problem, but it won't hurt to try it.
http://www.toyotanation.com/forum/10...out-tools.html
2015 RAV4 Limited, AWD, tech pkg, Barcelona red metallic, 28k miles
1996 Avalon XLS, ABS brakes, super white II, acquired w/ 139k, now at 349k
1992 Camry LE, V6 (3VZ-FE), ABS brakes, dark emerald pearl, owned since new. Replaced HGs @332k, totaled at 384k miles
BMR is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Camry and Solara Forum > Camry 3rd & 4th Gen (1992-1996 & 1997-2001)/1st Gen Solara (1999-2001)
User Tag List
Linear Mode Linear Mode
Back
